ZUKIWORLD Discussion Forum => Technical Discussion - Performance / Modify => Topic started by: madmax on January 18, 2016, 07:21:59 PM
Am looking at a sami divorced Tcase for 1st gen ranger. Will be behind 351w c4 . ? How well do they survive big tires and a v8
Kaboom! It will not last behind a V8 and large tires. The Samurai transfer case was designed to be bulletproof behind 1000cc/1300cc engines and relatively small tires.
Also, Samurai cases have a 41% reduction in high range. That is, they are not 1:1 in high range.
Good luck on your search!
Bad idea.... You need a case designed for a full sized rig.
Will you be driver or passenger drop? This is important to know if you need help locating a T-case.
As the stock Ford is a driver drop and the Zuke is passenger I'm assuming you have SAS'd the front end with something other than a Ford axle....
Dana 18 / 20 / 300 / or an NP205 are all available in a divorced format, or can be converted to divorced.
Pictured is a Dana 20 divorced terra low twin stick conversion
