ZUKIWORLD Discussion Forum => Technical Discussion - Beginner / Repair => Topic started by: Samuramateur on March 14, 2016, 05:47:48 PM
My "new" 1986 Samurai has an inconsistent bad misfire.
I've put a couple cans of "Heet" thru it and replaced the fuel filter. I changed the plugs, wires, distributor cap and rotor.
What should I try next?
It comes and goes. It seems to run better after I hit a hard bump and then worse after I make a tight right hand turn.
Thanks!
Problem solved. I replaced the coil and it runs great!
