ZUKIWORLD Discussion Forum => Suzuki 4x4 Forum => Topic started by: WVzuk on July 22, 2016, 01:54:54 pm
So I bent my driver's side A-arm or suspension lower control arm. I did this actually a while back but I am tracking down a pulling problem when braking. I know its likely the braking system that is responsible for the whole thing but i want to replace the arm to eliminate the variable.
I have a 1994 4door kick. What other years are compatible? Are the two doors the same? Anyone want to sell me one?
Jon
I don't have a book to compare part numbers, but I would guess 89-98 would all be compatible, across the 2 door and 4 door lines (excluding the sidekick sport models).
Hopefully someone that has access to part numbers will reply to confirm.
I don't have the part numbers but I can tell you we have swapped them around between years and models. So you should be good. :)
I do not believe there is a change unless you go to a Sport or 2nd gen model.
