ZUKIWORLD Discussion Forum => Suzuki 4x4 Forum => Topic started by: Warent on January 25, 2017, 08:14:32 pm
Title: K10A Gearbox into LJ80
Post by: Warent on January 25, 2017, 08:14:32 pm
Am wanting to replace the F10A in my LJ80 with a K10A Turbo running an Auto gearbox. Can anyone recommend a suitable box for the job. Will a gearbox from a Cappuccino or Carry do the job?
Title: Re: K10A Gearbox into LJ80
Post by: Drone637 on January 26, 2017, 11:58:14 am
The LJ still has the divorced transfer case, so you should be able to use any automatic transmission that has a rear output.  I believe the Carry has the same drive train and the SJ-410, so that would be a good swap.
You might want to double check though, it's been a while since I looked at doing a 1.0L Turbo swap.
