		ZUKIWORLD Discussion Forum => Classified Ads => Topic started by: herman pahls on May 14, 2017, 11:38:03 PM
				Hello Forum
 Time for another project so my 1997 Geo Tracker, 4 Dr, 2.3 Aerio engine, 5 spd., Kreator 5" lift with front coilovers is up for sale.
 All the work has been done for you and buying all the pieces cost more than what I am asking.
 To see photos and follow the build go to Technical discussion- Performance/modify May 23, 2016.
 Call, text or email for more photos.
 The Kreator lift uses 2-1/2" longer front  A-arms which give 10" of wheel travel.
 Right front axle was converted to use left side axles sourced from an XL-7
 Spare front axle included.
 Photos show the Tracker on 31" BFG All Terrains on stock wheels.
 Included are new (100 miles)  33" BFG All Terrians on new aluminum slotted wheels.
 Also included is a Trail Tough 4.24 to 1 T-case plus the stock ratio T-case.
 For Moab I install the 4.24 T-case and the 33" tires.
 For the sand and all around off roading I use the stock ratio T-case.
 I have things set up so that i can switch T-cases in 2 hours.
 Wiring harness mods and  motor and T-case mounts came from Trail Tough.
 Trail Tough supplied all the conversion pieces like exhaust manifold, water pipes, oil pan..........
 Current installing a Center force dual friction clutch and pressure plate since the 2.3 Aerio is too hard on the stock clutch.
 Body and upholstery are clean.
 Has tow bar attach points.
 Trailer hitch that protects the gas tank when rock crawling.
 Without lockers this Tracker performs great on the rocks.
 On the sand dunes and dirt this Tracker is amazing.
 $8000.  or best offer
 Herman Pahls
 Coquille, Oregon
 Cell 541 404 6464
 hpahls|removethispart||removethispart||removethispart|@gmail.com
 Please call, text or email
 I prefer not to private message.
 Thanks Herman
