ZUKIWORLD Discussion Forum => Technical Discussion - Performance / Modify => Topic started by: DOWNEASTER on May 29, 2017, 08:06:31 pm
Hey guys just kick'n this toyota front cv /trackkick swap idea around.. From what i know about it (which isnt much) looks like a stronger setup .So what would be needed as far which years toy parts etc. are needed for this swap on a 1998 tracker...?
The easiest way to do it is this way; you need 3 things:
1) do the Hagen widening mod (search it)
2) make up a stub shaft that inserts into the passenger side of your diff that has the same 3 bolt flange as the driver's side
3) buy this kit and it should all just bolt on if you've done steps 1 and 2 correctly: http://www.zukparts.com/Suzuki-Vitara-to-Toyota-Hilux-CV-Conversion-Kit (http://www.zukparts.com/Suzuki-Vitara-to-Toyota-Hilux-CV-Conversion-Kit)
(http://www.zukparts.com/image/cache/data/Suzuki_Vitara_to_Toyota_CV_Kit-340x340.jpg)
Hey thanks for your response. I've seen this conversion on one of the zuki sites afew years ago. My rig is a 1998 2dr. soft top 1.6L 16v 5spd. which I've done a far amount of work too,lol.I'm running the Alter Ego 4.5" suspension kit,Calmini 3" body lift, 5:85 R&P sets,lockrights front & rear, 150 amp GM alternator swap, 32" 11:50 BFG-KM2, 55amp H.I.D. light conversion,Calmini winch bumper with matching rear spare tire carrier bumper out back,XRC PRO 9500 winch,power streering cooler,rebuilt front & rear diffs ,steel front diff housing, rolled the rear spring cups mod.S.S.header,gauges in pods(oil-temp-volts),43"Curved highout put LED off road light,and much more been done as well as more mods to come.And one up coming mod will be this toy cv conversion.Tho first I need to rebuild my 5 spd trans and transfer-case.And like always its not just the rebuilding or replacement of tho two items,I'd toss a new clutch ,pressure plate and throwout bearing(centerforce brand),solid trans mount as well as solid transfer-case mount.plus a set of 4.24:1 transfer-case gears.As I want to go up too 34" tire size and the little 1.6 L 16v motor has all it can take even with up gearing to 5:85's.I would love to rebuild it and port the head plus add a LARGER cam,10 to 1 pistons ,etc.. and maybe it will push 150 to 175 hp.lol more than enuff to spin 34" 13.00 boggers even in a hard spot.Anyway this is why I been looking at the toy cv axle swap.
SO,I wonder if the "Hagen widening mod" still needs to be done with my setup....? The Atler Ego kit replaces the stock lower control arms and moves the front wheel,etc. ahead 1.5 - 2 inchs or there abouts.Which is what he was trying to do on a smaller scale.. There is a Zuki member who did this type of mod. with a suspension lift kit like the setup I run,he is outside the U.S.A. and seems to be part of a 4x4 motor cross club as well as a member of the zuki ones.He took great photos of all the mods he did as well as explaining everything. I cant remember his name to save my ass.lol. Tho if I remember right this site lost a bunch of older post memory,like a year ago(?) and his build record mite have been part of the lose,And thats why I cant find anything in the build diaries of this member and the awesum work he did.
As I understand it, the reason behind the Hagen widening mod was to get enough clearance to run a left side axle on the right side - does the Alter Ego kit allow this or does it use the normal right side axle?
If you can get Alter Ego to answer that you'll have the answer to your question.
Hello Fordem,thanks for your input as its greatly appreciated as always,as is everyones.You may be right about the widening mod. and the extra clearance gained was a plus. The Alter Ego setup runs regular axles tho it mite be easier to use one axle for both sides the way its setup,I've not looked into it as yet.But I will ask the company about it.
I've never really looked at the Alter Ego kit, but the Hagen mod requires a stock left axle for the right side, and a stock left axle plus a spacer, so, if the Alter Ego kit uses stock axles, I'm guessing you may have some challenges.
The reason why I term them challenges is the Hagen mod moves the wheels out and forward, based on what you say the Alter Ego arms also move the wheels forward, if you have both, you could potentially have the wheels too far forward - maybe Alter Ego can do custom arms that also space the wheels outwards.
Just a suggestion - if the Alter Ego arms won't allow for the use of two left axles, take a look at the Calmini Anvil - it's a steel axle housing that replaces the aluminum one and allows the use of two left axles - that might be a solution.
I searched for that Toyota CV kit for a year and finally gave up.... and then here out of no where someone posts a link where I can just buy it. apparently I suck at researching ::) thank you olija!!
Did anyone ever find out if alter ego or calmini arms extend the arms far out enough to avoid doing the hagan widening mod?
Hiya,
I am looking at doing this in the next 6 months or so, with kit mentioned above.
If you follow the link it recommends Surf/4 runner Cv's and locking hubs to suit.
I have just used Tims disc brake conversion kit for my 92 Vitara, highly recommended.
https://www.zukparts.com/Suzuki-Vitara/Suzuki-Vitara-rear-disc-brake-conversion-early-axle (https://www.zukparts.com/Suzuki-Vitara/Suzuki-Vitara-rear-disc-brake-conversion-early-axle)
Cheers.
Wouldn't it be more worth your while to swap a Toyota IFS axlehousing in with the Toyota CV's? Just thinking about putting big Toyota CV's in with a chintzy Suzuki front diff seems like you're moving from a relatively inexpensive, easy to replace weak link to an expensive, difficult part to replace. I guess the main issue is that you'd have to run a Toyota rear axle too probably because there are no matching ratios unfortunately.
Hmm will the calmini Lower control arms bolt on and allow the same side axle ? Or will I need to do the Hagen mod aswell?
I am currently doing the Toyota IFS swap with the kit as pictured 2 posts above.
Needed
1 Kit from Australia or is it New Zealand? I have had it for years and just getting to installing since I went to 35" tires.
2....Hagen mod or in my case the lift kit I am using already has 2-1/2" wider and 1-1/2" moved forward A-arms.
3 2 Toyota IFS front axles from 1986-1095 pickup. these CV axles make the Tracker axles look tiny.
4 2 Warn manual locking hubs part number 28761 or equivalent.
5 Left side axle conversion to the right side so you can use same axle both sides
I also had Trail Tough assemble for me an all steel front diff and housing.
Sounds like fun. You should post up some pictures, a buddy is looking to switch to Toyota CV's.
Needed
Hmm i wonder if this will work with the calmini a arms. I have to add this to the list if i dont have to widen it
Regarding why I went with Toyota IFS front axles and the required Hagen Mod (or 2-1/2" wider A arms in my case) and right side stub axle conversion to use the same axle on both sides.
You only need to carry one spare, they appear to be way beefier and so far I have not heard them click like the stock IFS Tracker axles do from my experience.
Even though I have yet to break a Tracker IFS axle on 33's, I did not feel they would last long on the 35" tires I recently started using.
If you are only planning on using up to 32-33" tires and no front locker, I would stick with the stock Tracker axles, but do the right side stub axle conversion which requires the Hagen mod.
The advantage of staying with Tracker axles is that if the sway bar is removed, the axles can be replaced in a few minutes without jacking up the vehicle or removing the wheel and tire.
If you're hearing the stock CV axles clicking, it'll be because they are worn and need to be replaced, not because they are in some way inferior to the Toyota axles - the Toyota axles will also click when worn.
I agree that worn CV's will click, be it Suzuki or Toyota; so will CV's that are asked to have more angle than they were designed for.
I have 2 Trackers, both of which the stock CV's did not click until I lifted them.
Of course the clicking is only when under load and when approaching full lock steering.
Not all CV's are designed to tolerate the same combined angle; the steering angle plus the increased angle when doing a lift.
The Toyota axles I used were salvage yard finds.
Possibly they did not click because they are designed to handle more combined angle than the Suzuki's or I was lucky that they were in better condition.
What I know for sure is the Toyota CV's make the Suzuki CV's look miniature and therefore assume they are more up to the task with 35" tires
I just want to bulletproof this sidekick and make it a fun lasting offroad and road friendly 4x4.
I hear people are doing the drivers side axle mod without the hagen mod. I hope i can pull that off. From sounds of it the 26spline Suzuki axles should be plenty for me. I plan on a arb front locker as well. Maybe a chinese unit haven't decided yet.
Darel at vitmods says he can weld up the drivers side mod and maybe make it a little shorter to compensate for the length of the driver's side mod without doing the Hagen widening mod. But he only has the 22 spline stubs in stock. I want to swap to 26spline and steel housing asap.
I have some 31x10.5r15 Couragia M/Ts.
Before I went with the 2-1/2" wider arms on each side and using stock A-arms, I did the left side axle on the right side without the Hagen mod..
To make this happen required machining and welding the new right side stub axle as short as possible.
In my situation this required that the lower 2 bolts that hold the right side differential bracket were converted to countersunk bolts and the 3 bolts that bolt the axle to the stub axle were also converted to countersunk.
With the Hagen mod countersunk bolts would not be needed.
Since I have yet to have a CV axle failure (I have worn them so they start clicking) with 32-33" tires in 10 years, I would probably just carry both axles as spares.
Then when the right side axle fails it will require a lot of work to change out on the trail and then u will wish you had the 2 left side axle mod.
This is good to know, I wouldn't mind running left side axles on both sides, but I am not keen on widening the track any.
A few questions if you don't mind ...
a) Is this on a first or second gen vehicle?
b) What suspension modifications did you have at the time - I believe lift affects this as the axle length becomes shorter as the suspension droops.
I have acquired a complete front axle assembly that matches my second gen, so most of the parts needed are probably already on hand.
That Tracker was a 1995 2 door.
Not sure what generation that is.
The lift was a trail tough 2-1/2" springs and shocks.
Before starting the right side to a left side axle conversion, measure the left side from a repeatable point and transfer that measurement to the right side.
This measurement will tell you exactly where the new stub axle to inner CV interface needs to be.
Maybe I did not need to do the countersunk bolts to get the needed length
Thanks much for the details...
A 95 is a first gen, or SE series,.
Instead of a widening mod on the frame we just modified the end of the a-arm to have a new mounting position for the lower ball joint. Might be easier to go that route if you want to sit a bit wider and lower. We have found that moving the mounting point 1 1/2” forward and 3/4” wider on each side gives you extra room for the tires and does not change your steering geometry.
I did need to have a spacer create for the drivers side to stop blowing out the stock CV's after the mod.
That's not really an option on a second gen - they have cast LCAs with an integrated ball joint - I'm not about to shell out the coin for aftermarket tubular arms, hence my curiosity in how it was done with the stock arms - I'll probably find the time this weekend to put the CV axles side-by-side and evaluate my options.
I finished the install of the Toyota IFS front axles last fall using the Australian conversion kit and tried them out on the Rubicon.
This was also my 1st time on the trail on 35 x 12:50 tires.
These little Geo/Suzuki's are amazing, but as you all know it takes serious modifications.
In my group was a leaf spring Toyota on 37's, a custom rock buggy on 40's and coil overs and a new Polaris turbo S with stock coil over suspension.
I was the only one without lockers and struggled more than they did on the more difficult obstacles.
My point in mentioning the other vehicles suspension is that they all commented that my Geo appeared to get down the trail faster and smoother than they were comfortable traveling..
I feel this is an advantage of the Geo IFS front suspension and rear coil springs and 35" tires with 8 psi.
Ten miles into the trail I lost front wheel drive.
I had lost the bolts that hold on one sides locking hub, and all the rest of the bolts to the locking hub adapter and hub were lose on both sides.
Since returning home and using lock tight, the bolts are still coming loose with local wheeling on 31" tires.
I never had bolts coming lose on stock Geo locking hubs with which I was using 2-1/2" longer Vitara left side axles to go with the 2-1/2" longer control arms.
My conclusion is that since I am using 2-1/2" wider control arms and have more suspension travel than stock control arms with the Hagen Mod, that I am either binding the Toyota IFS axles
or exceeding the angle that the Toyota CV's were intended.
The next issue is that with the adapter needed between the hub and warn locking hubs, the locking hubs stick out too far and I have already damaged the warn hub cover with the engagement knob.
It reminds me of a 70's Chevy pick up on narrow tires.
As I said several posts ago before I trail tested the Toyota IFS axle conversion, I would stick with the stock Suzuki axles, do the conversion so you are using left side axles on both sides and carry a spare which will only take a few minutes to change out on the trail if the sway bar is removed.
i will be going back to the Vitara axles and see how they hold up to the 35" tires.
i may need to carry 2 spares.
