ZUKIWORLD Discussion Forum => Suzuki 4x4 Forum => Topic started by: rickstar on March 26, 2018, 01:18:54 pm
I have a 2001 v6 auto grand vitara there is a grinding noise in my front diff. it comes and goes intermittently it appears in 2 or 4 wheel drive and also if i roll in neutral
I have disconnected the vacuum hose and still there. it is on the right hand side of car more than the left.
any ideas
broken CV or chipped ring and pinion
The ring & pinion should be stationary in 2WD, so that rules that out ...
I would jack up the front and roll each side individually, with TC in 2wd. I would suspect either CV's or wheel bearings.
Thanks guys i have replaced wheel bearing and still there i will check cv
