ZUKIWORLD Discussion Forum => Suzuki 4x4 Forum => Topic started by: Alaska101 on March 01, 2004, 12:05:32 PM
Title: Zuki Will Not Start????
Post by: Alaska101 on March 01, 2004, 12:05:32 PM
Any Ideas?? I have not checked spark or gas but it is too dark out now, so I though I would ask if there are any comon things. I turned it off an the about 2 min. I tryed to start it all I got was Starter and nothing else.
Thanx
Title: Re: Zuki Will Not Start????
Post by: HotRod on March 01, 2004, 01:46:36 PM
whats your milage? It seems to be a popular answer but does it seem to turn over quicker now?
First guess would be timing belt or a silly fuse.
Post by: WV-TrailRunner on March 11, 2004, 02:53:51 PM
Turn your key on... get you a 17mm socket... and turn the crank slowly with the coil unhooked... listen for the injectors to open and shut... if you dont hear anything then you may have a broken timing belt or a bad connection at the distributor where the wires plug in at the bottom... check the ground near the back... or take the valve cover off and see if the cam turns.... good luck to ya cause i've been there not too long ago...
Post by: zuktinter on January 23, 2009, 09:45:20 AM
if it is carburated sray some starting fiulid in the carb and see if it starts,if so it must not be getting gas.
check for spark.
take off oil cap and turn over to see if cam and valves or turning.
Post by: 90camozuki on January 23, 2009, 10:18:57 AM
this post was from 2004. I hope he has got it cranked by now....... :laugh: :laugh: :laugh:
Post by: zuktinter on January 23, 2009, 01:31:54 PM
Lol guess I didn't notice the date.
