ZUKIWORLD Discussion Forum => Suzuki 4x4 Forum => Topic started by: Buckettooth on November 15, 2018, 01:37:24 pm
Hello,
So, I swapped a 2001 Chevy metro g13b engine into my 88 samurai, and am currently stuck on the wiring.
If anyone has information or tips for installing the entire harness, it would definitely be of help.
Pulling the engine with the harness connected would have been ideal since I'm guessing you can't run the engine with the samurai ecu.
I think the manuals you'll want to check out are here: http://www2.izook.com/library/ (http://www2.izook.com/library/)
Good luck
I had already pulled the harness out of the car the entire harness is there I'm just not very intelligent when it comes to wiring everything I need and what to get rid of
If you go to that iZook library or ours (available through home page) look for the wiring schematic from 'warbird' that's the simplest explanation. If all else fails, call Brent at Trail tough and send your harness in. They will make a plug and play harness for you.
Good luck, Eric
