ZUKIWORLD Discussion Forum => Suzuki 4x4 Forum => Topic started by: skidr1 on February 23, 2004, 03:15:29 PM
Does anyone know off hand which manufactures stock wheels will fit the tracker/sidekick? My local Pennysaver and auto trader type papers are full of take off wheels:
Jeep Wrangler and cherokee
chevy 5 lug truck wheels
ford five lug trk wheels
etc. Are the bolt paterns right on any of these?
yep i think the ford 5 lug nut will fit the ford f-150's are 5 on five and a half i think and they fit sidekicks
ya they do.
I know Mac is running ford rims.
I think the Wrangler's are a bolt on too.
You are looking for 5 on 5.5" wheels.
Ford F150 trucks used these up until around 95 then they went to a metric size,  also full sized Jeeps... whatch out for the newer models, most use 5 on 4.5" wheels
later model dodge trucks(mid to late 80's and up) also use the 5 on 5,5" bolt patern.
be sure to check the center hole  and back spacing
too .
ÂÂ
1-Jeep Wrangler and cherokee
2-chevy 5 lug truck wheels
3-ford five lug trk wheels
1- Nope, the wrangler and cherokee will not fit. The CJ rims will fit though
2- I'm not sure about this one but I'm thinking no.
3- Yep, these will work on the older Fords. Just check the lug spacing for 5 on 5 1/2 and make sure the center hole is larg enough for your hub.
Hey, new black steel rims aren't that expensive. You might be better off that way. You can even custom your own back-spacing if you want. It just takes a little more time.
