ZUKIWORLD Discussion Forum => Suzuki 4x4 Forum => Topic started by: derekj on July 06, 2005, 05:19:22 PM
Title: Re: trouble bleedign my brakes(tracker/sidekic sys
Post by: derekj on July 06, 2005, 05:19:22 PM
check your lines to make sure that they are not collapsed or blocked with crap. did you take the bleed nipple right out of the caliper to see if it was plugged? that is a common problem with bleeders even more so if it has been in a lot of mud or sitting outside for a while. good luck
Post by: chopper on July 06, 2005, 05:33:48 PM
i didnt take the bleeders right out but i will give that a try tommorw any othere ideas? its on both claipers too nothign no fluid at all
Post by: chopper on July 07, 2005, 10:59:12 AM
ok figured it out
