ZUKIWORLD Discussion Forum => Suzuki 4x4 Forum => Topic started by: cj on January 20, 2004, 08:34:33 AM
I see Trail Tough www.trailtough.com list an Economy Rear Disc Brake Kit. Has anyone done this on a Kick?
"This basic kit includes the pieces necessary for the do-it-yourselfer to put Samurai front calipers and rotors on the rear of your Samurai OR Sidekick."
Sidekick
Item #ERD-401 Price $ 99.00
**Note - this kit makes NO provision for e-brake or proportioning.
I would be interested to hear of anyone's experiences with disk brake conversions for Trackicks, too. I think it would be advisable to have the brake proportioning valve as well as an emergency brake, so one of the kits that uses components from other vehicles would probably be better.
Satarn Calipers and front tracker disks
Saturn Calipers huh? I would definitly like to see this set up.
Yeah dude, show us some pics! :) I'll even host them for you if ya like.
Ford Sierra (Probe?) calipers and Sammi discs
Whats the Sierra caliper size as it would be great to match up a suitable master cylinder. Maybe the Subaru or a RAV4 master cyl might work.
The Sierra calipers would allow an e-brake setup, yes?
Worst case on any rear disc conversion you can get Wilwood mechanically actuated calipers pretty cheap as long as your disk is pretty close to the thicknesses they work with. You also would have to make provisions for the mounting bolts for them.
Yes thats why we chose them, well that and the fact that there are so many in the breakers yards they're pretty cheap. Size wise I don't recall, the piston diameter is pretty close to that of the Sammi though
Maybe i'm totally out of the loop, but why not Suzuki Swift GTi/GT rear disc calipers?
seems to make the most sense.
Hard to get.
At the end of this Artical I installed Saturn calipers.
http://www.zukiworld.com/month_070103/feature_hagen_ford9inch.htm
Mike
i cant find the kit on the website any help would be apreciated
Are you talking about Trail Toughs kit Or what I did on Zukiworld?
What model Saturn ?? I checked every
one the other day and they were all drums
On to the brakes. I chose 99 Saturn SC2 rear calipers to use with 2 door front rotors from a Tracker. I made the brackets from semi frame steel also due to its strength.
Hmm, most definitly would like to see a pic of that setup. All the stopping power the better.
http://www.zukiworld.com/month_070103/feature_hagen_ford9inch.htm here this is what he did the brakes on.
Stu
Yeah I saw that, not much help though as far as telling you how to actually fabricate the mounting system.
I seem to recall someone saying that they weren't up to the job on a Track/Kick
i plan on doing the tt sammy kit.......
i already have an sj 410 parking brake.............
