ZUKIWORLD Discussion Forum => Suzuki 4x4 Forum => Topic started by: rushaburee on January 20, 2004, 01:28:01 AM
Title: Too hot inside my Zuki
Post by: rushaburee on January 20, 2004, 01:28:01 AM
Happy new year to all.
I have a Suzuki  Escudo 1991 model. Whenever I drive it for about a hour, it becomes uncomfortably hot inside. I begin feeling hot air coming down from the front (not from the vents but from below the dashboard) and becomes very hot inside. yet the engine is at normal temperature.
So where does this heat come from and what can I do to stop it??
Thank you
Rushabure
Title: Re: Too hot inside my Zuki
Post by: wildgoody on January 20, 2004, 03:23:02 AM
the heater core always has hot water
flowing thru it, you might have a stuck
open flap, or not fully closing flap on
the heater box.
Post by: ghd23 on January 20, 2004, 04:28:19 AM
The only thing I can think of is to drive around naked!!!!
Post by: Speedracer7c on January 20, 2004, 04:58:09 AM
Well if you were a hot chick that would be one thing but your not. Mine always blows a little air even when the blower isn't running. I just put the vent to recirculated air and it stops it.
Post by: rushaburee on January 20, 2004, 04:47:01 PM
Thanks for all the advice, but I can never put off clothes inorder to drive. Anyway, I tried closing and opening vents and any other adjustements you may think of but nothing seems to work.
Whatelse can I try?
Rushabure
Post by: wildgoody on January 20, 2004, 04:52:40 PM
I said stuck open, as in you need to get
under the dash and adjust it, I had allready
guessed you tried to close it with the lever.
Post by: mrfuelish on January 20, 2004, 05:26:50 PM
I found a piece of silicone stuck in my heater valve, I just drained the system into a pan and pulled off the clip holding the cable on it and two screws and the two heater hoses and it was off the fire wall in no time and i just used some pliers to pull the junk out of it hooked it to the garden hose and made sure it was clean and it now works good! I guess somebody got carried away putting in a new thermostat .  I also back flushed the heater core while I had the garden hose out.   Dennis.
