ZUKIWORLD Discussion Forum => Suzuki 4x4 Forum => Topic started by: trk2ajk on January 15, 2004, 12:12:21 PM
Title: auto kick body lift
Post by: trk2ajk on January 15, 2004, 12:12:21 PM
 ??? i have a 96 4x4 4dr kick and plan tolift it to fit 235 a/t tires on aftermarket steel 15x7 rims.
  this vehicle is strictly a mall cruiser, i just want some alt/att-itude. with rro's 2" body lift, will i run into problems with my auto trans. will there be a gap? would i be better off going with coil spacers? trying to do this on the cheap so my real money can go towards more firearms. i have searched and did not find? thanks, the real badzuki
Title: Re: auto kick body lift
Post by: mahimahimo on January 15, 2004, 01:19:34 PM
ive got 235's on my auto tracker and the acceleration and stuff is fine, but the biggest plus in the highway the rpms stay much lower. they rub a little wit my stock suspenion im gonna do the 3 inch calmini boddy lift which will stop that .......good luck
Post by: Tracker_Gt on January 15, 2004, 06:39:48 PM
iam runnin 235's totally stock suspension and they only rub a little and its only when i turn all the way left
unelss your springs are sagging i see no reason you cant run 235's stock like me
oh yeah and it is nice on the highway too iam getting much better fuel mileage now. i just cant do big smokey burnouts any more dont quite have the power to get the 235's spinnin the way the old 215's did (better for my wallet that way any way hehe)
Post by: Mr._NSX on January 15, 2004, 06:51:59 PM
You will not have any problems, it will fit fine.
Post by: Z3bra on January 15, 2004, 11:18:08 PM
Also since the automatic transmission is a cable linkage, it has plenty of slack in the cable to accomodate a lift.  I have the Calmini 3" body lift and didn't have to do anything as far as the shift lever goes.
You will have to bend the transfer case shifter a little bit and would probably like it better if you weld an extension on it.  If you can't get the equipment to bend it (torch) you can alternately notch out behind where it is on the tranny tunnel and just relocate the boot a couple inches further back.
Post by: mavapa on January 16, 2004, 12:21:02 AM
Maybe this is a good thread to hijack for a question on body vs suspension lifts. Which is the easiest/best to do, slip in some longer springs (say 1.5 inches), slip in the coil spacers, or use a body lift? I want a mild lift without adverse effects on handling, driveline angles etc.
Post by: Z3bra on January 16, 2004, 01:13:58 AM
I can't speak for the suspension lifts since I don't have one yet, but I found the body lift pretty easy to put on.  The only hard part with the body lifts is the bumper situation.  If you have a concrete floor, a floor jack (A big one with the 4" pad/disc thing not one of the ones with the cheesy little 1.5" pad) and a couple 2x4's that's all it takes aside from the usual hand tools to do the worst part of the body lift.  You do have to weld the spacers that go on top of the frame to the frame (although mine still have a gap betwen them and the rubber pads on the body so I'm not sure how necessary it really is).  And you have to weld the bumper adapter brackets to the frame in the front with the calmini 3" body lift if you want to use the stock bumper cover and not have a gap.  There's also the shift lever issue I mentioned in the earlier post.
Other than that it's really nothing difficult. Bolting and unbolting stuff pretty much.   If you don't have a floor jack (or even a big enough bottle jack to reach the 2x4's) I could see it being much harder.
A body lift obviously doesn't change any of the driveline angles and there's no real handling difference since the engine and the other heavy stuff stays the same height relative to the ground as it was before.  True you do raise the center of gravity slightly, by raising the body, but on a 2 door with a soft top you don't have much heavy material above the bottom of the windows so it's probably not that big of a change.  If you do a suspension lift you're still going to raise the center of gravity and even moreso than just a body lift.
Post by: lil_Truck on January 16, 2004, 01:47:23 AM
(http://groups.msn.com/_Secure/0TgADA!EWcGdZKxlwpqMq*KN3Cl4QMSCtEgjewzZBN9YbULHrb6kLwKirmmcpZN2!nQps2xEgjVQ5F*ZZSaFeDtV0u3Nla3E0!xMXW8hyXwXynWv5Sa8NPg/DCP012140.JPG?dc=4675455813670008449)
This was my tracker a couple years ago.  It has the Calimini 3" suspension lift.  And I'm running stock rims with 235/75 R15's on it.
With the body lift, the only ground clearance you gain is from the larger tires.  With the suspension lift you gain 3" plus the tires.
When your going off roading it's all in the clearance.  I wish I had my lockers back then.  I would of loved to see what I could have gone through with just 235's on her.
The front was very stiff untill I later got the Calimini bumper and winch.  That suspension is made for the added weight.  If you were just going with the stock bumper I'd cut a little out of the coil.
As for installation, it just took normal hand tools.  The hardest part was all the rusted bolts that were stuck into the rubber bushings.
Title: .if i understand this correRe: auto kick body lift
Post by: trk2ajk on January 16, 2004, 01:53:47 AM
 thanks for the replies,
  z3bra,  i had read that there was a cable linkage  to the tranny shifter, if i understand this correctly, when i lft the body, the transMISSION shift lever will raise with the body. the transFER CASE lever will not come up and that will have to be extended and/or bent. is that correct.
  i have a good floor jack, lift stands, hand tools etc. a pretty good knowledge and moderate skill working on vehicle lifts. perhaps spacers will be a better way for me to go.
  feel free to hijack this post with a "spacer v/s body lift discussion.
  glad to be here on this board. been on the or.c board as badzuki for a couple of years. lurked here for the last 6 months or so.  thanks, tommy
Title: Re: .if i understand this correRe: auto kick body
Post by: lil_Truck on January 16, 2004, 02:07:47 AM
Yep, but I didn't see mention anywhere about the steering shaft.  You will have to have a exstantion made for it (something like 1 7/8" cant remember the exact number).
If your just going for the 235's I'd go with the spacers.  You gain nothing with a body lift except for tire clearance.  The 235's will fit and work most of the time on a complete stocker.
So with the spacers (and maby flip the mount on the top of the strut) you would just be eliminating the exstream conditions where the tires would rub.  And you will also get additional frame clearance under the truck.
Post by: Mikerpm4x4 on January 16, 2004, 02:35:25 AM
If you had no plans on adding a Winch bumper in the future I would rather see you go with the 2 inch Calmini kit. It was designed to run without the weight. I would always do a suspension lift first.
Mike
Post by: Z3bra on January 16, 2004, 03:20:11 AM
Ack, you're right I totally forgot about that.  For mine I just cut the old one in half with a sawzall and found a piece of 4130 tubing that I slip fitted over it (had to grind the old shaft down ever so slightly to get it to slip over it).  Then I just used my drill press and drilled holes through it on each end through which I put some high grade bolts.  Could have welded it instead but leaving it bolted makes for easy removal when I have to.
Make sure you use good locknuts if you go this way and use 2 bolts on each end for redundancy.  Having the bolts drop out while you're driving probably wouldn't make for a good day.
Post by: trk2ajk on January 16, 2004, 04:44:31 AM
  thanks all,
    i think iam going with spacers.
 now, wheelers spacers are 3/4". rockyroad's spacers are 1 1/8". sky mfg spacers don't fit on the rear  (right?)
does anybody else make spacers of a larger hight? 2" is what  i want. some where i read that you can use tj spacers, but you have to modify them- i prefer not to do this. thanks again, tommy
   also , i read that 3/4 inch spacers gave 1.5" of lift, so any spacer i use will give twice it's hight in lift (right?)
Post by: Somer on January 16, 2004, 11:52:06 AM
I think that just doing the coil spacers will be much easier, but actually the 2" RRO bodylift will not be as difficult as mentioned above.  I think that you only get those problems with the Calmini 3" bodylift.
  I don't have an auto tranny, but I didn't have to do anything to the steering shaft or the transfer case to get the lift to fit.  The only thing that I did was flip the transfer case boot up side down.  Maybe save a few more bucks and do both the coil spacers and the bodylift.
Post by: trk2ajk on January 16, 2004, 01:26:55 PM
can you stack spacers? safely?
Post by: Z3bra on January 17, 2004, 12:13:42 AM
You can get away without extending the t-case shifter but it's just easier to use with the extension.  Even with a 2" lift while you don't absolutely have to extend the steering shaft it's probably not a bad idea, It's not meant to be pulled tight all the time which is what you're doing if you do a body lift without extending it slightly.
Dunno maybe it's just an experience level thing, but I really didn't find the body lift to be that big of a deal all in all.
Post by: sarmeier on January 17, 2004, 02:01:13 AM
Just did a  RRO 2"  body lift on a 2 dr 1997 Tracker.  Worked fine without extending the transfer case lever or an change to shifter.  It took about 2 hours to do, longer on the driver side with the learning and a little more to disconnect.  Be careful to make sure you have all the  misc stuff losse when you lift the body so nothing hangs up.  Overall not a big deal and the lift along with RRO spring spacers give enough clearance to run 30" tires.
Post by: ppltrak on January 17, 2004, 10:03:25 AM
I used A homade 3/4" aluminum spacer front & rear and got about 2" of lift and could probably run 29x8.5 tires no prob.
