ZUKIWORLD Discussion Forum => Suzuki 4x4 Forum => Topic started by: jagular7 on January 09, 2004, 03:10:59 PM
Title: Front body panel swap
Post by: jagular7 on January 09, 2004, 03:10:59 PM
Since most of the 3rd gen. US models, ie. Vitara, XL-7, X-90, of Suzuki use basically the same mechicals, I wonder if the front body panels are swappable. For example, taking a X-90 front fenders, hood, bumper, headlights, and swapping them onto a Vitara or XL-7.
Title: Re: Front body panel swap
Post by: 92Sidekick4x4 on January 09, 2004, 03:41:54 PM
hhhhhmmmmm i dunno have you tried to do a google search on it? thats what i usually do when i have ideas (usually dont pan out) but its worth a try  ;)
Post by: Zukipilot on January 10, 2004, 04:57:20 AM
I doubt it :( I just looked at mine (X-90 and Kick) and it does not look like it would bolt on. After the snow melts off the X I will look at it closer.
Post by: SpinalTap on January 10, 2004, 05:26:20 AM
I doubt that any of the panels would line up properly. The doors are shaped differently, as is the cowl. I suspect the XL7 is wider than the X90 so the hood wouldn't be wide enough leaving a nice big gap between the hood and fenders. Can it be done? Sure...but you'd best be a dern good bodyman if you want it to turn out right ;)
