ZUKIWORLD Discussion Forum => Suzuki 4x4 Forum => Topic started by: douglas on January 09, 2004, 01:32:46 AM
Title: severe hesitation
Post by: douglas on January 09, 2004, 01:32:46 AM
Anyone have a severe hesitation on their sammi?  Mine started about 2 months ago.  It always happens when I stop and then accelerate (stop sign or light).  I suspect the accelerator pump on my weber 32/36.  Seems that air is getting in that circuit, which causes a lapse in squirt when accelerating (I have cleaned that circuit and all the jets thoroughly).  I am soon to check the timing too.  I have a 1.3 engine with a weber.  There are new plugs, wires, cap and rotor.  No other engine mods.  Thanks.
Title: Re: severe hesitation
Post by: wildgoody on January 09, 2004, 02:38:01 AM
Sounds like a leaking accelerator pump diaphram,
gets some air in there and spits before it squirts.
Good Luck with it    ;)
Post by: brace on January 09, 2004, 03:23:24 AM
I have a factory suzuki on my SJ and the guy before made a second accel. pump diaphram made out of a tire inner tube.  I rebuilt it with the a kit from Hawk and now I out run larger mopeds.
Post by: douglas on January 09, 2004, 05:48:22 AM
Would you see gas leaking from it or maybe the whole might be too small?  I looked at the diaphragm and decided that it looked good  but maybe not.  Keep the ideas coming cause I'm all out of brainstorms. ???
Post by: wildgoody on January 09, 2004, 04:26:11 PM
Blockage in the passage that feeds
the Accel pump, or the 1 way valve,
read bearing with a spring, might be
out of place, rusted, stuck, broken...
Dirt blocking the squirter, you do have
a fuel filter on don't you ??? if not, dirt
could get in there.
Post by: bandit86 on January 10, 2004, 01:37:06 AM
dont forget the vacum lines, if any. I had a hose come off a PVC valve once, man it was wierd.  It would idle crappy, nothing but missfires/ hesitation till full throttle.
