ZUKIWORLD Discussion Forum => Technical Discussion - Beginner / Repair => Topic started by: RalphARoni on November 04, 2019, 02:24:46 pm
I am removing the radiator before replacing Timing belt, water pump ect. I removed the 2 bolts coming in from the top sides and it can tilt backwards at this point. It looks to me as if there are x shaped plastic pieces and rubber sockets holding the bottom in. Do I just pull up hard to get it out or is there something I have to do with these lower mounts first? Sorry I couldn't get a picture. Close area. Have to remove the radiator with the shrouds on it because of corroded bolts. Have already removed fan clutch and upper hose. Will remove trans cooling hoses and cut off lower hose first. Thanks.
Just give it a tug, but make sure you keep those pieces. They are bushings to keep the radiator in place.
