ZUKIWORLD Discussion Forum => Suzuki 4x4 Forum => Topic started by: RalphARoni on January 12, 2020, 02:11:53 pm
Our 96 2dr is basically unmodified but the tires are a couple of inches wider than the original and stick out a bit less than an inch. Sometimes I want mud and it has to get on the roof even but in day to day riding I dont. I saw these $30 foam self stick ones but they look crappy and easy to tear. Nothing else I can find looks like it would match up. Has anyone found any? I'll use 3m tape to hold them on if I find any.
Low Range Off-Road has a set you may want to look at.
Pricey but possible the best option.
http://www.lowrangeoffroad.com/1989-1998-suzuki-sidekick-tracker-2-door-fender-flares.html (http://www.lowrangeoffroad.com/1989-1998-suzuki-sidekick-tracker-2-door-fender-flares.html)
(http://www.lowrangeoffroad.com/media/catalog/product/cache/1/image/900x675/213c2f08e8867d794ab84c36c21cfda1/3/7/375448_10150370996046912_677096911_8425107_167684909_n.jpg)
Look serious! I have to see if they make it in a one or perhaps 2" option. I might want to put them on with em foam tape to avoid making holes though. I'll do some checking.
They also offer this style (http://www.lowrangeoffroad.com/flexy-flares-side-mount-rubber-fender-extensions-2-25-wide-and-4-25-wide-by-the-foot.html) in a 2.25" size.
(http://www.lowrangeoffroad.com/media/catalog/product/cache/1/image/213c2f08e8867d794ab84c36c21cfda1/p/p/pp_484_pacer_no_lip_3x.jpg)
I think I would like that better. I'll check it out. Thanks
I used a set of 3" JC Witney flares. Drill and rivet every 4 inches, works pretty well. If I had the time I would take off the inner plastic liner and weld a 1" lip on the inside of the fender well to give a bit more purchase.
(https://lh3.googleusercontent.com/5cwqD0ACUYRA7OUyFMJ93DyuIJqgdSiLDa41qhX7BROUHxOtzJawUKxAKMk8bKp2CIhewlSu2GpSJuitLZ5wKCAWGBBHmsqlU9Ryb1CSFzJ0P8So8Y68gWSoqUhbtKeQw3wtyA_yVGAAtx2FfcwV7EAS1_Jx_lSw8R26i_k0PhEr56NXYQAeXqvb0PF5nqZGy0b3QZjVkQ0pdzatLU6JwfJU84Q3T6RZXokKxWiJI7Khc4BRoC9eMElh2ueDvMh_yzi9p7WgYUc-k2aTZY-zoXe7u_UbcDv5IU4ExEippgfOobrscMKb5OpWM0-v7XMj0DoLlgtdPUo4pDi8uGQJkOZ_qVfrn6oB2GRqIBVqApH1ewLznfEfhzVeUKFFjDWJ86aaJKEdc68iaAQ8h363JM0IwW9cQmJDIJaEP5H92NuEBAtTUJ3rp5Am_B36P4zjpy27TnUYulCL_95YSSyNQR5Es91fT18p_OD1VeHKprir5aRN4g_pMRM3Q8S6ir68wbzW7u_K3aqwUyz84Ii_uQAP8IrPOXjNEc4zgHEvi8BfQrQvQdO01fvyT_32P3bOUV5BNQvqap9-pYe1Uh9SQixGx0BOZhfh3HIJSMVIFO9cBMDHN49Snb35uPkmDpuiBa2Y2FrDf5ZIKlPHs4OYhps0FQQIaxYPo1BLAZrT6bw_LFxOGPEHoVwQ01CyofTfdaDyWvDKmcfr2eL7w02_wAXHj80MoYiTTBJFUnZpyhJCNghRtg=w1395-h1046-no)
This looks like it would suit me fine. I would put them on with the 3m tape that holds the solar on our RV so no holes. I looked on JC Whitney and could not find them. I am sure I will pass a JC Whitney sometimes in my travels though and if I can find them. Thanks
They may not sell them anymore, it's been quite a few years since I bought any and I usually picked up a box from a swap meet. :D
It does look just like a generic kit from Amazon.
https://www.amazon.com/Pacer-Performance-52-189-Reinforced-Extension/dp/B00029X0ZG/ref=sr_1_11?keywords=ez+flares&qid=1580246444&s=automotive&sr=1-11 (https://www.amazon.com/Pacer-Performance-52-189-Reinforced-Extension/dp/B00029X0ZG/ref=sr_1_11?keywords=ez+flares&qid=1580246444&s=automotive&sr=1-11)
