ZUKIWORLD Discussion Forum => Technical Discussion - Beginner / Repair => Topic started by: ontario410 on September 28, 2023, 04:45:55 PM
i changed my oil pan gasket at the beginning of summer and still had a bit of a leak so i got under and re torqued the oil pan bolts to 8 foot pounds which i found on a chart online. all of the bolts retorqued fine however one of the bolts where the engine mates the transmission behind the small sheetmetal cover is not torqing up and i believe is stripped. has anyone had this problem? im assuming i will need to put a helicoil in? or is there another way to repair?
thanks
A helicoil is what I would consider an easy repair - and by the way, Suzuki doesn't use oil pan gaskets, just RTV sealant.
This is a good idea.
I ordered a cork pan gasket directly from megazip a OEM part
