ZUKIWORLD Discussion Forum => Suzuki 4x4 Forum => Topic started by: mahimahimo on December 02, 2003, 10:22:46 AM
since x-mass is comen up im gonna use it to my advantage lol....im looken at the mickey thompson classic two wheels size 15x8. Im also looking at the BF Good Rich all terains size 235.75r15. will i have any problems with rubbing on a stock hight and if i will have any problems will the 2 inch suspension lift help at all....thanx for your help
I had 245/70r15's on mine when it was stock and had no problems,there a tad shorter than 235/75's but wider. 235's might rub when turning into drives and such. With a 2" lift there shouldn't be a problem.
see the thing is im just worried bout the 2 1/2 inch back spacing . ill do sum measurments to see cause i no sum one posed on the forum sum one put 30x9.5 on thier stock tracker and he said no rubbing
Good looking wheels, over priced tires,
personal oppinion, I like the Pep-Boys
Tires, AT would be Durango, MT are the
Enforcer, I have used their tires for many
years, never had any trouble, or flats for
that matter.
Depending on the offset of the wheel 235s could fit. However I got a feeling that they are gonna rub. 2 inch lift will easily clear them though.
Mike
I had my brothers 235/75/15 Kumho tires on my sidekick with totally stock suspension and the things didn't rub and all with normal driving and turning but when the suspension was flexing the wheel wells would cut into the tires.
that matter.
I also feel the same way, I haven't used the Pep-Boys tires but I just got a new set of Good Year M/T's and they are way better than the BFG M/T's. The Good years where aslo about $10 cheaper each for 31in tires.
15"x8" are very too wide for 235-75 r15 tires
They will fit more on stock 15"x5.5" rims.
Fredo
Fredo
yeah, when I mounted my brothers tires they where on 15x7 rims and they didn't rub. I think 15x8 might be pushing it.
Well heck, for that matter I shoehorn 31x10.5s
onto stock rims ;D
i went to my local dealer today he said the wheels and tires are a good set up and will fit fine ... mr nsx wa was the off set on the back spacing wit the rim u used to fit the 235 75 r15?
I have a 5.5 inch Spring over axle lift and my 33's still rub the springs at full lock.
the wheels are on order....i measured everything from what i could see i cant imagine them rubbing
