ZUKIWORLD Discussion Forum => Suzuki 4x4 Forum => Topic started by: zukizzy on December 31, 2004, 03:08:48 PM
Title: Wild Doors
Post by: zukizzy on December 31, 2004, 03:08:48 PM
Here are a couple pics of wilds doors. they are far from done but you can get the shape. :o
(http://photos.zuwharrie.com/users/zukizzy/P1010169.JPG)
(http://photos.zuwharrie.com/users/zukizzy/P1010168.JPG)
(http://photos.zuwharrie.com/users/zukizzy/P1010167.JPG)
we had a good wrench sesion and I got a quick school on kicktracks, now I can at least know what some of you are talking about. We'll be doing this again so watch for good things to come. like some new axle mods a couple brace kits and even some more tube work. ;D
Wayne
Title: Re: Wild Doors
Post by: HotRod on December 31, 2004, 04:02:30 PM
they are looking good.
Post by: Speedracer7c on January 01, 2005, 02:51:48 AM
Those look badass!
Post by: 92Sidekick4x4 on January 01, 2005, 07:40:55 AM
they look awesome
Post by: whitfield on January 01, 2005, 08:39:12 AM
Slick,   I like it.
Wild Doors, OR Wild's Doors...   ???    I'm confused...
Anyway, Welcome to the dark side of the Family, Where EFI, Powersteering, and 5.13:1's are the norm.
Post by: explosivo on January 01, 2005, 09:40:36 AM
Kick tube doors would rock. I was thinking of running doorless on my rig once I get it done... of course if tube doors for the kick were in production... hey, hey, hey ;D ;D
Wait, power steering? Whats that? :P
Post by: HotRod on January 01, 2005, 03:23:39 PM
"ArmStong" for those luckie few. I guess I should be happy I got luckie and got the 16valve and ps on my first venture into ZUKISM ;D
BUt I think that if you run without doors you should have something to keep your body in incase of the unforeseen.
Post by: zukizzy on January 01, 2005, 03:24:57 PM
Hey guys had a good day after the newyears hangover wore off :P I got Wild's doors about done and have a few pics I need to get uploaded just no time to do it on dial up. you'll have to wait till I get in the offfice monday. you think I should paint the drive one RED?   ;D
We were talking about easy remove doors a while back and while we were at it wild and I came up with a couple easy solutions. I;ll post some pics later but here is the short version. the stock Kicktrack hinge uses a 8mm pin. that is for all intents the same as 5/16" you can get several pins at home depot or your local hardware store that will slide right in. The best would be a cotterless hitch pin. then a cotter hitch pin with a spring clipat least 2". All you do is take your door off remove the circlip and drive out the stock pin then put the new pin in and re bolt your door. It takes 2 people but you can remove the pins without unbolting the door and go doorless. Pics to come ;D
Wayne
Post by: zukizzy on January 01, 2005, 03:27:00 PM
Slick,   I like it.
Hey whit still looking to get into a trackick but I know you got one to spare ;D too bad your so far away till then it sammys for me.
Wayne
Post by: 92Sidekick4x4 on January 01, 2005, 03:33:21 PM
Wayne
cant wait to see them
Post by: HotRod on January 01, 2005, 03:44:40 PM
I just noticed, Did you have to take the fenders off to get the hinges off?
Post by: explosivo on January 02, 2005, 04:12:56 AM
You do have to take the fenders off to get the hinges off the body, at least.
Post by: wildgoody on January 02, 2005, 11:48:45 AM
Hi all  :)  I'm back from Ocotillo Wells, met up with
PPLTRAK and his dad, they were both driving some
nicely modified kicks, Calmini 3" suspension lifts and
swampers for traction, looking good you guys.
Well for the tube doors, we removed the fenders
so we could get in there and get the hinge pins
out and unbolt the doors, but once the initial instal
is made, and the pins are swapped to the easy pull
hitch pins, the door swap will be much easier, and
fender removal would be optional, tho not as easy
as a Sammy with external pins and hinges.
It might still be a 2 man operation to put the
stock doors back on
Wild doors or Wild's doors, both apply  ;)
Post by: zukizzy on January 03, 2005, 02:00:51 AM
Yes we did but wild can take off his fenders in about 30 seconds (like velcro pants ???) so it made it easier. you don't have to but it is way easier if you do.
Wayne
Post by: ppltrak on January 03, 2005, 03:12:27 AM
Those doors look sweeeet ;D. Ya Wild for some reason I don't think you would have wanted those doors on this weekend. I,m still trying to get the mud off the kick.
see ya,
  Kevin
PS Zukizzy I heard that your shop is in menife I live off clinton keith if you ever need help in the shop let me know.
Post by: zukizzy on January 03, 2005, 03:23:01 AM
see ya,
  Kevin
Kevin
I see your splash all over the place, passed ya the other day with the sammy in tow behind my red cheby on Los Alamos. I will need a little measurement help with the Kicktrack stuff I will give ya a pm . trying to dig out of the mud right now.
Wayne
Post by: Bobzooki on January 03, 2005, 09:15:08 AM
You gotta paint them things red Darin!
And maybe add some chrome-yellow clamp-on mirrors!
:o
Post by: wildgoody on January 03, 2005, 10:01:55 AM
  see ya,
  Kevin
You remove the mud from your Track/Kick ???
That's just wrong   ;)
Wild  ;D
Post by: ppltrak on January 03, 2005, 10:22:15 AM
Well 2000#'s is alot of mud. I could hardley get up the hill to come home.
Post by: wildgoody on January 03, 2005, 10:26:36 AM
That just means your not jumping enough
;D
Post by: zukizzy on January 04, 2005, 01:46:22 AM
(http://photos.zuwharrie.com/users/zukizzy/P1010170.jpg)
Ok so left to right here are an asortment of pins we tried for removable Kick doors.
1/4 " cotterless hitch pin. too small but the prefect pin if you can find one in 5/16"
3/8" cotterless hitch pin. I thunk I could take out the bushings in the hinge and try this pin but no go. get one that is 5/16"
5/16 uiniversal clevis pin with a spring hitch pin to keep it in place. Thins will work but is hard to get in and out due to the lack of a grab ring. also the top one has to go from the bottom up due to clearance. This is why the spring pin.
5/16" spring clip pin. Again a great pin easy as any of them to get in and out but the spring clip gets in the way of the door if you install it from the outside, or the rubber seal if you install it from the inside, which is easier anyway. It could be modified with a BFH to clear but the cotterless hitch is prefect. Im' looking for a bulk supplier now.
Hope this helps
Wayne
Post by: keith on May 11, 2005, 01:38:32 AM
Did these doors ever reach production status?
Post by: nc_zuk on May 11, 2005, 02:17:07 AM
All you gotta do is PM Zukizzy and order some ;)
Post by: Natebert on May 11, 2005, 03:50:47 AM
Are they supplied with proper 'pins' ?
~Nate
Post by: hcgalvin on May 11, 2005, 08:17:07 AM
([url]http://photos.zuwharrie.com/users/zukizzy/P1010170.jpg[/url])
Hope this helps
Wayne
(http://forums.bradbarnett.net/html/emoticons/red-x.gif)
Post by: Natebert on May 11, 2005, 08:52:54 AM
([url]http://forums.bradbarnett.net/html/emoticons/red-x.gif[/url])
Fortunately, those brain dead error messages that IE supply aren't visiable in Firefox.
No little red 'X's for me!
~Nate
Post by: hcgalvin on May 11, 2005, 08:59:18 AM
~Nate
Yup, in Firefox.. it just completely ignores the fact that there may have been an image there... so there's nothing at all..
Post by: Natebert on May 11, 2005, 08:59:38 AM
But wait, somebody PM'd me !!!!
(http://www.omghi2.us/april05/redx.jpg)
Now I can enjoy it like the rest of you!
Glad that Firefox doesn't pollute my pages with images I can't even see to begin with.
~Nate
Post by: explosivo on May 11, 2005, 09:51:39 AM
Ow, damn! My eyes!
Someone needs to turn on ClearType for sure :P
