ZUKIWORLD Discussion Forum => Suzuki 4x4 Forum => Topic started by: Zuki One on November 14, 2003, 09:10:42 AM
Title: Anyone done the Front Knuckle overhaul on a ZUKI??
Post by: Zuki One on November 14, 2003, 09:10:42 AM
 :-/Any body done this i havent?difficulty level? best priced kit?Any info would be better then none so come on give it to me!ooh iknow and you know that their are certain tricks to this trade so if anybody knows any good secrets or tricks to make this job any easier lay it on me pleez. Thanx much!
Title: Re: Anyone done the Front Knuckle overhaul on a ZU
Post by: mrfuelish on November 15, 2003, 01:49:56 PM
There not too bad! you just have to clean every thing real well and don't get too impatient, I used some glue on the felts and large seals to hold them in and getting the cups out of the knuckle might be hard if you do not have a seal puller other than that just a lot of grease everywhere what a mess it can be! on going back together make sure to use a torque wrench on all the bolts even the small ones.  sky has a sale on them for oct. but maybe he does not know that it is already nov. sky-manufacturing.com 99.00  thats about half price if you can still get them there!
Post by: Zuki One on November 15, 2003, 02:42:47 PM
Was that 99.00 for bothsides or one ?thanx 4 the info any is worthy :D
Post by: mrfuelish on November 19, 2003, 06:41:18 AM
I sent this once already but I guess it did not take? yes that is for both! check out the web site.
Post by: r0ckstarr79 on November 19, 2003, 07:44:24 AM
I will be checking that out as well....... Thanks for the info!
Post by: wildgoody on November 19, 2003, 11:28:32 AM
Barfields......er Birfields and grease, they go together.
There has to be a better solution over these, I've never
had one apart, but a friend tells me they are like a CV
joint inside the knuckle, well you see how the TrackKick
CVs hold up :-/ , I know U-joints are for Heeps, but I
wonder if it might be a better part for heavy duty use.
??? Thoughts ..... Coments ???
Post by: mrfuelish on November 19, 2003, 01:03:00 PM
I know for the toyotas they now make a bif, eliminator that looks like a dana 44 axel with the ears and a u joint that fits like a glove, too bad they won't make one for the zuk family >:(
Post by: wildgoody on November 19, 2003, 01:10:12 PM
I'm going to start some HD replacement parts,
starting with a Rear Disk Brake Axle for both
Sammies and Track/kicks, and while I'm at it a HD
front that will work for Sammies and Track\kicks
Well Sombodys got to do it ...............
Post by: Zuki One on November 19, 2003, 04:58:29 PM
ooh,oooh!!do it do it Iwant one! :D
Post by: wildgoody on November 20, 2003, 04:49:59 PM
Which one ?? Front or Rear ???
