ZUKIWORLD Discussion Forum => Suzuki 4x4 Forum => Topic started by: BigKick on November 09, 2003, 08:29:03 AM
Title: What needed to put 4dr Kick brakes on 2dr?
Post by: BigKick on November 09, 2003, 08:29:03 AM
Im picking up an 96 2dr trackick and was wondering after the lift and 31s, I was going to step-up the front brakes to 4drs. Didnt know if 2dr spindles were the same and all I needed is the rotors and calipers, or if I have to swap everything. Help the newbie please.
Title: Re: What needed to put 4dr Kick brakes on 2dr?
Post by: wildgoody on November 09, 2003, 09:51:42 AM
It's a direct bolt on, just get all the stuff
from a 4 door, install and bleed the brakes.
List:
Backing Plates
Calipers
Rotors
Bracket that holds caliper to spindle (bigger bolt pattern)
kep all the old bolts too, just because you never know.
Crap I even grabbed the pads while I was there.
The rotors on the 4 door are ventilated, you could use the
stock 2 door but why, vents cool way better.
The only thing I didn't grab was the backing plates, a slight
tweek with a big Crescent Wrench and it all fit good, so if ur
on the cheep and the backing plates are too much, use the
old ones, they will work fine.
You might want to get the rear brakes too, I didn't but it would
be a total upgrade that way, and an easier brake petal. ;D
Post by: BigKick on November 09, 2003, 11:50:35 AM
But the front brakes are bigger arent they, or are they just vented?
Post by: safarikick on November 09, 2003, 12:06:53 PM
do the sidekick sport  brakes fit on a 2dr  ???
the original thickness on the disc
0.394 on 2dr
0.670 on 4dr
0.866 on a sidekick sport
on the rear brakes the original inside diameter is
8.66  on the 2dr
10.00 on the 4dr and the sidekick sport
Post by: wildgoody on November 09, 2003, 03:25:01 PM
I don't know what the Dia of the sport brakes are,
What I do know is the 4 door brakes have bigger
pistons in the calipers, which gives better clamping
force with less petal pressure. they could be slightly
bigger too, but it was not obvious just looking at
them.
I thought the rear drums were wider, I didn't think
they were bigger Dia. I never did measure them
just an observation looking at one in the wrecking
yard. If they are bigger Dia. I'm going to swap out
those too. When you run 33s the better brakes make
stopping about the same as with 235 tires.
Post by: mrfuelish on November 10, 2003, 06:03:13 AM
I have a four door I picked up for parts for my samurai's what do you think the chances are that they would fit a samurai?? the front's or the rears? or both? does anyone have a picture of a four door spindle assembely or even a two door just to see how close they are or are the caliper mounts the same? what ya think???
Post by: Zukipilot on November 10, 2003, 06:57:39 AM
(http://izook.com/tech/projects/x90/images2/c1-21a.jpg) 2-door 89 Kick. Does that help? I'll look for another one later.
Post by: 97TRAKIN on November 10, 2003, 07:15:56 AM
Sidekick Sports use bigger calipers and rotors! You can't even fit a 15" rim from a Samurai or a reguler Sidekick on it with out spacers. The rim will hit the caliper.
I think the Sports use the same size front brake hardware as the 99+ Trackvits because I ran into the same problem when I was trying to transfer the after market rims from my crashed "97 Tracker to my newwer "00 Tracker.
Post by: BigKick on November 10, 2003, 10:16:46 AM
So if I run 4dr kick sport brakes on my 96 2dr, do I need to run 16" wheels to make sure that I clear the calipers, no matter what wheel I run? (you know how every manufacturer's wheels are alittle different on the inside of the wheel.)
Post by: wildgoody on November 10, 2003, 10:40:28 AM
You might be able to run the caliper, but not the rotor,
too big for the 15" wheel.
The caliper is what helps lots in braking, bigger rotors help too
but you can't use em so go with what works for your truck.
Post by: 97TRAKIN on November 10, 2003, 11:37:13 AM
My 2000 Tracker came with 15" wheels from the factory and it seems as if they are the only 15" wheels that will fit it. I know that there are other ones out there I just haven't found them yet. The inside of the wheel makes a big difference!
Post by: mrfuelish on November 10, 2003, 06:27:58 PM
Thank's for the pic's, mine has 15" rims also just the stamped steel type I guess I will have to pull the tires off to see if I have vented or not? and 10" rears or not!
Post by: Fredo on November 12, 2003, 11:53:57 AM
Y run complete knuckles, rotors, calipers... in front and complete 12 bolts rear diff with bigger drums from my roll overed 94 4 doors on my 92 2 doors tracker!
And the stopping power with the 31" are better!
Fredo
Post by: NY_SIDEKICKER on November 12, 2003, 12:35:23 PM
SO YOU GOT YOUR 2 DOOR ALL LIFTED AND READY TO ROCK NOW ....WAS SAD TO HEAR OF YOUR 4 DOORS DEATH BY DEFAULT  ;D     MATTY D... ANY REASON YOU DIDN'T GET ANOTHER 4 DOOR  ???  JUST WONDERING
Post by: Fredo on November 13, 2003, 02:38:03 PM
I prefer 4 doors but i don't have enough cash!
Fredo
Post by: NY_SIDEKICKER on November 14, 2003, 10:37:32 AM
OK THOUGHT MAYBE YOU GAVE UP ON THE 4 DR KICK FOR THE SLEEKER 2 DR  ::)   MATTY D....
