ZUKIWORLD Discussion Forum => Suzuki 4x4 Forum => Topic started by: van7559 on November 11, 2003, 02:28:28 PM
i HAve a 95 tracker and just had a three inch body lift put on. Calmini says you can't use your old boots, so what did you guys do?? I can't have a gapping set of holes in my truck
MY BOTTOM ONE IS ON WITH NO PROBLEMS....... BUT TOP BOOT WAS RAISING HOLY HECK WITH POPPING TRANNY OUT OF GEAR , SO ITS NOT BACK ON YET..BUT WILL PROBABLY BE LOOKING INTO GETTING IT BACK ON SOON.......
We are using BOTH of our old boots on our 3 inch body lift. (we extended both of the shift levers 3 inches too)
But we did have to flip the 4wd shifter boot around to keep it from pulling it out of gear.
~Nate
I also have both boots. I also extedned both shifters, but I bent my console mounting brackets to move the console back about 1/2 inch and it works fine.
The inside of my tracker is bare bones.(other then the CD player and heater) the floors are coverd in about 3 heavy coats of under body liner and its all muddy and crapy looking so only having the small shift boot fits it great. I had hole in the floor from other stuff untill i went up the riven(A.K.A a hole that on a watery day the water goes over the hood) and the water came though the floors and up to my wast. hello cocking gun. lol lata Stu
the base rubber on the 4wd shifter ( the one that looks like someone has cut out a starfish) all i did was to cut this front to back and no more jumping out of 4wd for me ;)
