ZUKIWORLD Discussion Forum => Suzuki 4x4 Forum => Topic started by: Mike71 on November 09, 2003, 04:53:19 AM
Title: need help with alt swap
Post by: Mike71 on November 09, 2003, 04:53:19 AM
i have 1 more 15" kicker coming so that will mkae 2 and i have 1 mtx 942 so thats around 900watt rms plus an after market HU
thats why i think ill need a new alt that and my lights dim already sooo i was searching on here and i cant find anything mabey i spelled it wrong :( but someone said something about a GM alt swap and i for the life of me cannot find anything on it
mabey if someone has a link? also can i use a 200amp alot on my tracker? since the things listed about probably wont last long =) im looking at a solox for my next project 5kwatt rms 10k watt max lol
any help would be awesesome =) TY
Title: Re: need help with alt swap
Post by: Usilton on November 09, 2003, 05:31:54 AM
An inexpensive way to your problem is to get an altima yellow top battery and a strike cap, capsitor for the times when you need more power. Ask any automotive stereo installer and he'll say the same thing.
Post by: Mike71 on November 09, 2003, 06:09:10 AM
the cap id need would cost about 300-400 bucks and the cap would make my small alt problem even worse because then my alt would be straining to keep up the sub AND recharge the cap with the music i listen to id drain a cap in the first 30 seconds of a song so then there would be more load on the alt for the rest of the time
but u think a batt would help? wouldnt i just drain the battery? i dont understand the battery thing like how to have more then one and stuff and how more then one makes it so i dont run the started battery down since they are all connected together
Post by: bandit86 on November 09, 2003, 06:25:27 AM
No you got it wrong.  A cap is not a drain on your system,  a cap is strictly like surge protection.  It function is to keep woltage from changin.  Thats why they use it with a bridge recifier to change ac current into a real steady dc.   When your subs start pounding, the whole charging characteristics of your car changes.  The cap just smoothes out the sudden large draws, allowing your alternator to charge at a more even continous rate therefore not creating such a strain.   More caps will not affect your car in a negative way.   Your car will even start better because now you have a cap thats keeping your system voltage higher when youre starter is trying to start your engine.   Mind you it is not fool proof.  Once you get to a level that your stereo is drawing more amps on average that your alternator can supply you still are going to start draining your battery.   Now really, how long do you want your system to pound for, other than impressing chicks.  I been through that phase and trustme, you get hearing damage pretty fast.  Now I have two 12subs in my basement that I dont use
Post by: bandit86 on November 09, 2003, 06:29:30 AM
One more thing, if you need a bigger alternator because you have a winch and a 2500cca battery then I'm absolutely with you, then you would need a bigger alternator.   Something else you could do is measure the battery tray and buy the absolute biggest battery you can shoehorn in there.
Post by: Crabzuki on November 09, 2003, 06:38:49 AM
I had the same problem you do, what I did is went with a Extreme Duty ambulance altenator and had a bracket built by an altenator shop, then I went with a blue spiralcell deepcycle battery. And waahlaa no more power glitches. Now I can sit with all my lights on stereo blaring, sub- woofers thumping and amps pumping the juice all without the engine running for 3 hours and still have enough cold cranking amps to turn the motor, and on the drive home the battery is charged up and ready to do it again. Total cost altenator & bracket 750.00, deepcycle battery 250.00 . Champagne pocket book is a must!  Since I take my toy around to car shows, I like it to be nice and no Mickey Mouse.  ;D
Post by: bandit86 on November 09, 2003, 07:13:06 AM
hi crabzuki, can you send me a pic of your alternator setup?
Post by: Mike71 on November 09, 2003, 11:36:04 AM
well i am going to be wheeling this car everything i put in is easy to take out..cept it weighs about 130lbs lol but eventually i will have a winch and an air suplly for filling tires but i have to get the lift first =)
Post by: Mike71 on November 10, 2003, 04:40:12 PM
no one has a linky? can i just give someone the 200amp alt and have them fab a braket? does it work that way?
