ZUKIWORLD Discussion Forum => Suzuki 4x4 Forum => Topic started by: JDMCRX on May 07, 2005, 06:35:30 AM
Title: Wheel Spacer probs ANYONE HELP
Post by: JDMCRX on May 07, 2005, 06:35:30 AM
Hey guys here is the situation
I got a 2001 Grand vitra and im putting the rims off my sidekick on to the gv but i need to get a 1" wheel spacer from ROCKY-ROAD i put them one temp and everything clears.
Here is the problem the center of the wheel spacer is too small by like 2-3mm i guess to center the wheel on the truck. Now the Sidekick has no lip and when u put the spacer on it it i uses the Lug nuts to center the spacer and wheel.
Im thinking of taking a grinder and just grinding the lip out of it and let the lug nuts center the spacer on the truck anyone im sooo stuck.
JOSH
Title: Re: Wheel Spacer probs ANYONE HELP
Post by: Rhinoman on May 07, 2005, 07:46:49 AM
I can't see any problems with grinding it though a quick spin in a lathe would be preferable.
Post by: mrfuelish on May 07, 2005, 08:45:27 AM
Thats how they center on the samurai (lug nuts)just make sure things are real clean and use blue loc-tight or green and torque to at least 55 lbs and let it set up for a day or more.
Post by: JDMCRX on May 07, 2005, 09:29:19 AM
ok guys yeah i would rather lathe them but i go the truck all apart and i need the truck tomorrow so it should be good just grind them so they fit then the lugs nuts should center them
Post by: JDMCRX on May 07, 2005, 10:18:39 AM
Any more sujestions
Post by: mrfuelish on May 07, 2005, 04:59:37 PM
Quit talking about it and gether done.
