ZUKIWORLD Discussion Forum => Suzuki 4x4 Forum => Topic started by: Brandon on September 03, 2003, 01:40:41 PM
Title: biggest tire size for a stocker
Post by: Brandon on September 03, 2003, 01:40:41 PM
whats the biggest mud tire that you can put on an 97 4dr sidekick?Will an off set wheel be a must for it?sorry about the stupid question,kinda new to the Suzuki world.. ??? :-[
Title: Re: biggest tire size for a stocker
Post by: Z3bra on September 03, 2003, 02:22:55 PM
235/75's are about it for stock.  Even then you might run into some problems with the part just inside the wheel well interfering.  What I'd recommend is getting one mounted as your spare taking it home and mounting it in the driveway, then checking clearance by turning the wheels lock to lock.  If there's a spot that's close, leave the wheel there and jump up and down on the bumper to make sure it'll clear throughout the suspension's travel. Calmini has a chart on their webpage that shows what tire sizes can fit with stock, body lift, suspension lift etc.
http://www.puresuzuki.com/tire_chart.htm
The rear shouldn't have any clearance problems with 235's though.
If you want to go any bigger you're going to have to lift it.  I just put 31x10.50 Dunlop Mud Rovers on my 2 door over the weekend and even with the Calmini 3" body lift I had to do a little bit of artful work with the sawzall and a hammer inside the wheel well in front of the door since for some dumb reason the factory design has about 2 inches of sheetmetal that enclose a bunch of empty space that sticks into the wheel well.  On the upside I didn't have to touch any of the outer fender so unless you look into the wheel well it still looks unmodified.  (I probably should get to putting up a damn website for all my car stuff one of these days I guess).  The 31's fit ok unmodified until you turn the wheel a little bit then they run into the bodywork that sticks out into the wheel well.  The rears didn't need any modification for the 31's with the body lift on there already. I'm also not running a back bumper, I think the pretend factory mud flaps might be in the way if they were still there.  I'm not using the recommended 2.5" backspace rims though, mine are more like 3.5" backspace on 15x7's.  With 2.5" backspacing, the problem of the edge of the tire hitting the bodywork up front will actually be increased slightly, possibly to the point of requiring cutting away visible parts of the fender.  No biggie just something to be prepared for if you go that route.
The 31's definitely look nice though, I had 235/75's on there before and the 31's are about right looking with only the 3" body lift.  Heck my wife even thought they looked better and she's not a car/truck person so that's gotta be saying something.
I honestly think for the 150 or so to buy it the 3" body lift is worth it.  A lot of people here say it's hard to install but I thought it was pretty easy all in all.  If you've got an automatic the only nuisance to doing it is the t-case shifter extension and bending the shifter lever, I didn't even bend mine, I just cut out a little bit of the sheetmetal in the hump and slid the whole boot back a few inches instead.  I'm not running my rear bumper as a result of that but after looking at the design of the stock bumper core, I don't think it's gonna make much difference in a wreck anyway honestly.  I also am just running the core of the front one now instead of the urethane cover since I didn't feel like welding the steel plates to move it up on there.  Installing it this way isn't maintaining a factory appearance obviously, so if that's a concern yes the body lift is going to be a bit more work.  If you don't care though it only took me about 3 hours to put the lift on using a hydraulic floor jack and some 2x4's.  You will have to weld some small spacers onto the frame afterwards, I'm lucky to have a buddy with a nice MIG welder so this wasn't an issue.  Even if you don't I can't imagine a shop charging more than 20 or 30 bucks to tack the spacers on there for you though.  As it is I still have a gap between the cab and the spacers that hasn't ever touched as far as I can tell which tells me the spacers might not be all that necessary but if you have passengers in your 4 door regularly I wouldn't recommend leaving em out.
Anyway sorry bout the info overkill there, kills time for me at work nicely though.
Post by: buckwheat on September 06, 2003, 04:04:20 AM
The biggest tire on the stock rims with no rubbing etc is 225/75x15.  If you want something a litte wider, you can go with a 235/70x15.  You shouldn't have any problems with those sizes and maintain the same ride qualities w/o no extra costs.
Off road you will be able to go any where w/i reason and you'll be amazed at it's abilities.
Post by: Brandon on September 06, 2003, 05:19:37 AM
so exactly how good does 4dr suzukis do like mine all around?i just bought it and i know nothing about them.im use to mitsubishi's and i do know of alot of cheap tricks that you can do on them,are the zuks the same??
Post by: wiretap_MD on September 06, 2003, 12:13:34 PM
Check this link out:  http://www.tsikot.com/forums/showthread.php?s=&threadid=7559
I just upgraded my tires from 235/75 to 30x9.5.  No problems so far.
Post by: Brandon on September 06, 2003, 02:27:27 PM
thanks alot guys,i think im going with super swamper 29x9.50x15s
Post by: NY_SIDEKICKER on September 06, 2003, 04:30:29 PM
nice looking vitara  :o
Post by: NY_SIDEKICKER on September 06, 2003, 04:32:14 PM
quote "I probably should get to putting up a d**n website for all my car stuff one of these days I guess).  "  Z 3bra let us know when you do so   we can check it out :)
Post by: Z3bra on September 06, 2003, 05:06:40 PM
Might work on it this weekend (sun-tues for me while I'm off)  Gotta setup my firewall and throwing a web server up is no big deal while I'm at it, definitely have the spare systems to do it with anyway.
Post by: NY_SIDEKICKER on September 06, 2003, 10:31:07 PM
SOUNDS LIKE YOU'LL BE HAVING FUN  ::)
Post by: Z3bra on September 06, 2003, 11:00:37 PM
Hope so, I'm being lazy and using a firewall specific linux distro for the firewall so it shouldn't be too rough, just more of a hassle setting up all the permitted ports etc.
Post by: brlj on September 07, 2003, 09:56:06 AM
I ran 30x9.50-15 on stock Tracker rims and no lift , with no problems. They were AT tires but they looked aggressive enough to have been MT's.
Bill
Post by: 1bigtracker on September 08, 2003, 08:44:35 AM
Hey, sorry my Q? is off the subject but 4G63NT,  is 4G63 refuring to the Mitsu's rice buring 4G63 motor?  Just wondering.
Post by: Brandon on September 09, 2003, 12:38:52 PM
yeah,thats whats in my eclipse :-/
Post by: 1bigtracker on September 09, 2003, 01:27:25 PM
cool cool, I got an Eclipse too but mine has the little sister engine, the 4G37.  but its far from stock  ;D
Post by: Brandon on September 09, 2003, 01:28:16 PM
what year?
Post by: 1bigtracker on September 10, 2003, 07:40:20 AM
94, y?
Post by: Brandon on September 14, 2003, 04:02:04 AM
same year as mine
Post by: 1bigtracker on September 15, 2003, 02:07:11 PM
O bad ass.  what have u done for mods?  I'm goin to do the whole F and F thing to it.  I got some good ideas so far but plans can always change ;)
