ZUKIWORLD Discussion Forum => Suzuki 4x4 Forum => Topic started by: trackenator on May 05, 2005, 01:53:51 PM
hi all. thanks 4 all the info previously. helped alot. my new ? is with my 3in body lift and 2in tj spacers all round on my 92 tracker what is the biggest tire size i could run? i have 31 x 10.50 x 15 with alot of room left.i want to go with 34 x 10.50 or even 9.50 can i ? without using a bfh? thanks all. im from toledo ohio anyone else near here? flat land no wheeling areas so it would mostly be my dd.
Check out my post about the Goblin's new shoes. I just put 33-10.50x15 Swamper TSL radials on a 93 Tracker running a 4" body lift and 1.5" coil spacers. I had to do some trimming and floor pounding to clear them and I noticed tonight while flexing on a rock that I'm going to need to do a little rear quarter panel modding as well. Not counting the fulcrum-lever effect of the IFS, I'm running a total of 5-1/2" of lift and you're running 5" total. Factor in the IFS effect of the coil spacers and you and I are probably about even. If you don't want to pound/trim, then I would guess that the biggest you can go is 32-10.50. Forget the 34's, you'll need to do some serious trimming/pounding to fit them!
u could probly fit 33x10.5 with a bfh (big fu** hammer). but 32's would be an easy fit. i would go with a tire that measures a full 32"s.
A cutting torch and a welder can fit a whole assortment of huge tires, without the use of a BFH.
~Nate
