ZUKIWORLD Discussion Forum => Suzuki 4x4 Forum => Topic started by: wolf66 on May 02, 2005, 05:06:03 AM
Title: How many spline?
Post by: wolf66 on May 02, 2005, 05:06:03 AM
I am getting ready to re-gear to 5.12's from 4.62's in my 1996 X90..............I thought the fronts were 26 spline for some reason, the guy who wants to sell em to me says:
"The front spline count of a 1996 model should be 22 spline and 1997 and later are 26 spline."
Does that sound right?  So the '96 X90 would have one size and the '97/'98 had another?
Anybody know for sure?
Only answer I have gotten so far was:
"Not necessarily.  The X-90s were all built in Kosai, Japan, not in North America, so they could have got the change earlier, or not at all."
AHHHHHHH!!!
Title: Re: How many spline?
Post by: Zukipilot on May 02, 2005, 05:11:40 AM
Wolf,
They did change in the Tracker/Kicks around that time. I would suggest just pulling your passenger side 1/2 shaft and counting the splines. Then you will know for sure what you have.
I'm assuming from your wording that you are buying the complete 3rd members instead of a R&P set.
Post by: zuksofhazzard on May 02, 2005, 05:16:18 AM
I have both F/R thirds from a 96 tracker lsi, 5 speed. I think they are 26 spline. My uncle tried using the CV's in his 91 and they didn't work. I'll double check my parts too. (which happen to be for sale.....) ;)
Post by: 1bigtracker on May 02, 2005, 07:26:38 AM
we put all the 26 spilne stuff in andrew's tracker and  put the front end parts next to each other and there was a slight difference in the size of the shaft,  just so everyone knows.
stu
Post by: Bobzooki on May 02, 2005, 07:54:49 AM
22 spline through 1995, 26 spline 1996 and newer.
Post by: SnoFalls on May 02, 2005, 08:50:58 AM
bob ... that's true for track/kicks ... but x90? I dunno, them might be different :)
Post by: wolf66 on May 02, 2005, 08:53:20 AM
But the X is just a Track/Kick with a different body.... :)
Post by: SnoFalls on May 02, 2005, 08:55:56 AM
stu
if your talking length of the shaft yup ... ask me how I know ...
http://www.zukiworld.com/cgi/yabb/YaBB.pl?board=suzuki_talk;action=display;num=1110515689;start=20
Post by: SnoFalls on May 02, 2005, 09:01:34 AM
sure it is ... :) ... I wouldn;t wanna guess the diffs between a JA built x90 and a CA built anything ...
FYI, some 26 spline shafts are 1/4" shorter than others ... (probably 95 only or some such) ...
Post by: Mikerpm4x4 on May 02, 2005, 01:34:08 PM
This applys to X90s too. Dans 96 X90 was 26spline.
Mike
