ZUKIWORLD Discussion Forum => Suzuki 4x4 Forum => Topic started by: mesjr2004 on April 12, 2005, 11:02:00 AM
(http://www.omghi2.us/april05/Pict0367.JPG)
(http://www.omghi2.us/april05/Pict0366.JPG)
(http://www.omghi2.us/april05/Pict0365.JPG)
(http://www.omghi2.us/april05/Pict0364.JPG)
(http://www.omghi2.us/april05/Pict0363.JPG)
(http://www.omghi2.us/april05/Pict0362.JPG)
(http://www.omghi2.us/april05/Pict0361.JPG)
(http://www.omghi2.us/april05/Pict0360.JPG)
(http://www.omghi2.us/april05/Pict0359.JPG)
(http://www.omghi2.us/april05/Pict0358.JPG)
(http://www.omghi2.us/april05/Pict0357.JPG)
(http://www.omghi2.us/april05/Pict0356.JPG)
any questions?
Very 8)
Now for a step by step write-up and it would make a great tech article for the archives.
i've got a few questions
is that flange off a suzuki, or is it a piece of steel that you turned down in the lathe then drilled?
once you had welded the flange to the slipyoke shaft, did you use a lathe to make sure the flange mounting face is square?
could you give me the specs on the size of the hole u drilled in the shaft, the tap you used, and bolt size etc.
cheers :)
cheers :)
the flange is a piece of 3/8" plate that was boared ,welded to the yoke then parted then faced off on both sides then holes were drilled .
the holes in the outpuit shafts had to be doared out with carbide tiped boaring bar becouse of the case hardning, the hole is .3320, or really close and .9deep, with a relief cut around the outside of the hole to just over .3750 and .1 deep to remove the case hardning away from the tap, really didnt want a broken tap .
it was then tapped 3/8-24.
i had planed to stud the shafts with locktite and use a nut on the flange for removeing it . the studs in the pict are 3/8"-24x3/8"-16,with 3/8 nylocks
l :o :oks good msjr where do you work, a machine shop or something :D
the more you guys figure out the less problems i'll have when I decide to do a SAS to get E.B. off my case
jason
im a sheetmetal worker now ,but used to work in a machiene shop for several years but got board waching mills and lathes run wile i stood their .
a buddy of mine has a machiene shop so i have a place to doo stuff for now , hes got all his equipment for sale.
id buy it but im planing on buying a house this summer or fall.
i love welding and building stuff as long as its not repeditve.
marshall
thanks a ton mesjr, helps a lot. hoping to make some inroads on mine this weekend. :)
Shaweeeeeeeeeet ;D
I'll send you my Parts ;) ;D ;D
Nice job.
That's fucking sweet man. Looks great.
Very  8)
I second that
that is awsume. ru going to do a tech article.
Great job!
I second that
Me too, and tell me wat those Slip Yoke Eliminators are and why you neet 'm :-[
SAS. so u can run slipyoke driveshafts and have more travel.
Yeah i have a question how much?and how do i get it done?
Sami's already have them. You don't need them. ;)
Cwkick
wouldnt know wear to start . im a dooer not a teacher. dut i mite if i knew what was required . i guess ,
wouldnt know wear to start . im a dooer not a teacher. dut i mite if i knew what was required . i guess , ÂÂ
Just take the pics you posted and describe each of them including what you're doing or what it shows and any measurements/tools used. Doesn't need to be a novel just the facts. Have a look at Mikes articles in the archives to see what to do.
the picts i have posted are finished products i didn't take any of the fab process . does someone else want some ? and whats it worth ? and ill do a article on thoes .
pm me .
Cwkick
I have a 4DR i am doing a SAS with!Uhmm duh i Know i dont need them for my sami but thanx for the great info anyways :o
As i stated before i need DO LET ME KNOW for my (4dr) ;D
Thanks, I think I get it now ;)
Sorry! I didn't realize you had a project. :-[
Cwkick
The term would be slip
shafts instead of slip yokes,
the shafts have the slip in
them instead of at the yoke
