ZUKIWORLD Discussion Forum => Suzuki 4x4 Forum => Topic started by: TheRedHorseman on April 04, 2005, 06:02:50 AM
on the main bearing caps for the 1.3 liter, do the arrows on the caps point to the front or the rear?
yes I spun a bearing and I think after checking clearance I put them on backwards. I'm thinking they are supposed to point towards the front but I'm not sure.
btw, the 2/3 spark plug swap let it fire right up, but now I've got a bearing problem for sure. will the madness ever end?
Main caps as well as rod cap and the
arrow on the top of the piston all point
forward, did you spin a rod or main ???
not sure yet the engine gets yanked in about 4 hours. I'll try to get some pictures of the carnage for you guys.
I have some pics to take of the carnage
in my engine, should be a good show
ok, turns out that I didnt destroy anything, the flywheel bolts came loose on me >:(
so I re-installed them to factory torque spec +5 lbs and blue loc-tited them. if they come out now I'll be amazed.
i woundn't have put a angry face there, i would have put a smiley face becuase of how happy i would be that i wouldn't have to yank the hole engine out and rebuild. ;)
stu
stu
A friend of mine did a clutch job before selling me a car. two weeks later, I heard this horrible grinding soun, followed by clunking. turns out, he lost one of the bellhousing bolts, but never bothered to look for it, it's only a 4 cyl mustang. I had to go over a bump for the flywheel to hit it lying under the flywheel and start smashing it around..... I thought I lost the tranny
the bad part is that I just got done rebuilding the stupid thing, so I would have been REALLY peeved if I had to do it again.
Bring it on! I want to see!
~Nate
yeah, bring on pics of carnage
