ZUKIWORLD Discussion Forum => Suzuki 4x4 Forum => Topic started by: cj on February 14, 2005, 04:02:56 PM
Title: ARB 27 spline sidegear swap
Post by: cj on February 14, 2005, 04:02:56 PM
Can anyone confirm that it is possible to swap the sidegears in an ARB rear Kick locker(RD79) from the standard 26 spline to the Dana 27 spline? Part numbers for the sidegears would be great too.
Title: Re: ARB 27 spline sidegear swap
Post by: cj on February 14, 2005, 04:14:28 PM
In reply to my own question I now have the answer. ARB have just confirmed that it was possible but they no longer do that sidegear. It has been superceded by a Dana 30 spline sidegear that fits  ;D
Post by: Gear on February 14, 2005, 06:50:12 PM
what are your plans??
I've been looking at rear axles for the GV after snapping 2 of them.
Post by: mbmarkyb on February 14, 2005, 07:18:34 PM
There isnt much in it on the 26 and 27 spline
26 spline diameter  27.4mm
27 spline diameter  29.5mm
What 27 spline shafts are you using are they custom ones or did zuki make a 27 spline, wont Dana 30 shafts be too short?
Just wondered how easy it was to get spares after all once you have a locker that should be less stress on one shaft and no sudden transfer of drive from one to another???
Post by: Gear on February 14, 2005, 07:23:54 PM
Don't know about less stress.  If I didn't have the rear locker on I would not have been able to put all the cars weight on the one axle.
Post by: mbmarkyb on February 14, 2005, 07:33:49 PM
not sure if its  me but the later suzuki stuff seems to be weaker,  like the 26 spline driver axle CV joint is smaller is smaller then the 22 spline
maybe the same with shafts,  I did notice the ARB diff works a lot better than any stock one even when not locked.  seems to transfer power nicely ,
Post by: cj on February 14, 2005, 08:28:26 PM
I currently have an ARB in the rear and am putting in 5.83's when they arrive. I've been wanting to put discs on the rear and thought how about a full floater at the same time. The ARB rear also takes the D30 27 spline sidegear which ARB have since dropped and the D44 30 spline sidegear which is for an even bigger shaft. The thought is now with that size shaft I could probably do away with the Lockout hubs and just have a drive flange omn the outer as the shafts are unlikely to break. Thinking about the possibility of using an 80 series Landcruiser rear (Discs already but $$$) or Taco fronts married to the Kick housing. Maybe change stud pattern at the front to match. Lots to investigate. May know a little more tommorrow, we'll see.
Post by: Gear on February 14, 2005, 08:33:32 PM
Keep us updated, as I could do the same things to the GV just make the shaft a little longer.
I still can't work out why they put drum brakes on a A$30K car :(
Post by: zukicon on February 15, 2005, 08:58:36 AM
mo input 8) very good topic
Post by: the_dude on February 16, 2005, 07:23:59 AM
Give spidertraxs a call If memory serves me correctly they are using 27 spline axles with suzuki 3rd members in the custom axles they make.
Post by: zukizzy on February 16, 2005, 07:37:14 AM
Waht you are doing is a Superior gear D35 axle upgrade. Use D44 xles in an ARB with 30 spline side gears. It works well in our YJs.
So if I read this correctly an ARB side gear will interchange with other ARB lockers and you plan to use the 30 spline from a d44 Arb in a kick diff then use axles from a d44./ I like it if it will really work. D44s come in all lengths from narrow track jeeps cj5s to full size chevys and fords. they would be long enough to do 2 for a kick ;D just kidding.
Wayne
Post by: ebewley on February 16, 2005, 07:58:33 AM
Are you sure you understood them? The "Dana 30 Axle Assembly" uses a 27 spline axle shaft. This is what I'm using in the CALMINI solid axle front end (Sidekick 3rd member / Dana 30 27 spline Axle shafts) under my sidekick. The reason I ask is because there has been 'camp fire' talk that since places like Superior Axle have been making a Super 35 kit which is a 30 splined Dana 35 axle VS. 27 using the ARB and custom sidegears that all of this would be backward compatable making it possible to have a 30 splined custom shaft for your Sidekick 3rd member and axle housing. Which would be cool! Needs research...
Post by: cj on February 16, 2005, 08:01:38 AM
ARB standardise as much as possible. Some sidegears can be interchanged eg. in some Nissan and Toyota ARB lockers the only difference is the sidegears. The old D35 locker (RD69) 27 spline sidegears can be fitted to the Suzuki rear locker and this is what places like Spidertrax do, only problem is you'll find you can't get them as ARB have deleted them from their line-up. They have informed me that a 30 spline sidegear is available though but I am still trying to get confirmation and part numbers.
Post by: cj on February 16, 2005, 08:05:56 AM
The old D35 Air Locker RD69 27 spline sidegear part numbers are 130904R and 131004R for those that are interested in this swap and may still be able to track some down.
Post by: lil_Truck on February 16, 2005, 11:24:29 AM
This is way cool sounding.  As I was considering a rear axil change.
but
I already have and ARB.  So if I can just replace the side gears, get some D44 axils and have them cut down to the right length!!!  ;D
Post by: cj on February 16, 2005, 11:29:32 AM
Got some bad news for you  :( Yes, ARB have made some 30 spline sidegears but there are only a couple left kicking around out the back and they don't even have a part number and they aren't planning on making anymore. I'm going to pick up a set tomorrow for myself  8)
Post by: cj on February 24, 2005, 08:07:04 AM
OK, update time. Confusion reigned for a little while but all is now clear. You have the choice of 27 spline sidegears (#130904R & #131004R) and 30 spline sidegears. If you want the 27 spline, Spidertrax and Trail Tough have just got a few in and there should be more on the way soon. The 30 spline didn't exist in the system but they do exist if you know who to ask as I went and measured them yesterday.
Post by: Gear on February 24, 2005, 08:40:50 AM
you only have 33mm dia hole for the axle to fit through into the sidegear.  so i think the 30 spline might not work.
Post by: Mieser on April 06, 2005, 07:40:39 AM
I have been thinking about this lately again....
The D30 ARB comes in both a 27 spline ( standard ) and a 30 spline ( upgrade ) version now.
The D35 ARB comes in a 27 and 30 spline also.
We know you can use a 27 spline ala Spidertrax and Trail Tough. If the 27 spline fits in the stock ARB locker the 30 spline should also. The stock carrier bearings should also work still right?
You could do a Ford semi-floating outer bearing like Trail Tough. They use Samurai Rotors and calipers ( or subaru ones for e-brakes )
I would like to see a full floater that was easy and mostly Zuk, and the mostly the same parts as the front to eliminate having a thousand different parts.
What about using Samurai or Sidekick spindles, bearing hubs, and brakes? The main problem I see is that the 1.31 (33mm) or 1.33 (33.3mm) 30 spline shafts are going to have to fit through. In an earlier thread I posted I found out that the sami splindle is 1.155". So the inside of the spindle needs to be bored out .155 ( plus clearance ). I do not know if the 1.155 number is with or without the little bushing inside the spindle. That might gain some room. I don't think you need that bushing for a rear floater application.
So that leaves hubs if you want to do a floater. That one is pretty easy. A stock Toyota Aisin locking hub will bolt on a sami spindle/bearing hub. They are 30 spline, though if I remember right the pressure angle of the dana 30 spline (carrier/diff) is slightly different than the Toyota 30 spline ( hub ). One works in the other but not the other way and I can't remember which. Another option along the same lines is that the drive flanges from toyta would also work for those who didn't want hubs.
Anyone know the specs on the inside dia of a sidekick spindle?
I know that swaping in a toyota or Ford rear end would be less work but I am after as light and strong as possible within the limits of 95% Zuk parts.
Post by: wildgoody on April 06, 2005, 03:36:22 PM
it's on my to do list, I should go out and take
the front hub spindle assembly apart on my
Kick since it's not running right now, too bad
it's dark out there and I don't have a garage.
Listen to me whine it's 65* outside and I am
compaining about no garage   :)
I'll see if I can get the spec as soon as I can,
i can measure the splined shaft that fits through
the spindle, and I know there is a brass bushing
in there to locate the axle stub shaft, BTW 2WD
Track/kicks also use the same spindle, but there
is a plug in the back side of it and no bushing
I'm curious if a Toyota side gear (made by asine
just like Suzuki stuff) would fit into a Track/Kick
rear 3rd member, and if a little machine work
would allow 30 spline axles to fit in there also
I need a wrecking yard in my back yard, then I
could do all this R and D in my spare time   ;D
PS  Maxima rear calipers have E-brake, and they
are made by tokiko, like Suzuki ones too, read OEM
supplier  ;D
Post by: mbmarkyb on April 06, 2005, 07:33:49 PM
ARB spec sheet if anyone needs it
http://www.markyb.co.uk/arb/ARB.pdf
