		ZUKIWORLD Discussion Forum => Suzuki 4x4 Forum  => Topic started by: Cwkick on July 11, 2005, 12:14:43 PM
				PM's!  I can't send one.
 I can't change my avitar.  I can change other things in my profile.
 Anyone else having problems??
 Cwkick
				Sounds like $DOCUMENT_ROOT/images/avatars wasn't set 0755 ...
 ??? ??? ??? I could've sworn it was dot-egg or maybe dot-muffin 8)
 I'm just trying to help eric out ... phpbb is probably a new thing to him and has it's necessities.
				But this isn't phpBB, it's SMF ;)
				Ok,
 I know there are a couple things so far that aren't working.
 A. SMTP needs set (this is causing an error whenever anyone wants/needs email sent)
 B. The .gif for Mark Unread is missing
 Are there any others? Please don't tell me you don't like this or that or this needs tweeked. Just post here with issues that relate to a broken part of the forum and I'll try to get them fixed right away.
 Thanks for your help, Eric
 whoops you're right ... never looked at the copyright down below  :-X
				I don't care for the way large images are handled to prevent table stretching... but that's less of a problem and more of a personal annoyance. :-/
				since this new format showed up i cant log in on my old user name.
 if i use the password reminder it says my username does not exist.........
 if i try to register using my old username it tells me that name is in use by another member???
 WTF is happening??
 i had to create a new name AND use another email address as it would not accept either of my old details??
 any ideas??
				and i get this error message after every post?
 An Error Has Occurred!
 mail() [function.mail]: Failed to connect to mailserver at "localhost" port 25, verify your "SMTP" and "smtp_port" setting in php.ini or use ini_set()
 mail() [function.mail]: Failed to connect to mailserver at "localhost" port 25, verify your "SMTP" and "smtp_port" setting in php.ini or use ini_set()ÂÂ
 Me too! The posts always shows up when I check but I can't delete a post if I try.
				Ok, please PM me with any further problems. As stated above, the email problem or SMTP issue is being worked on and that will fix a lot of these problems.
