ZUKIWORLD Discussion Forum => Suzuki 4x4 Forum => Topic started by: weaver on July 11, 2005, 07:43:18 PM
as i prieviously mentioned,,,,
also how do you alter the shifters? they sent me the extenders and i know i have to weld them , but where and how hard is this to do.... do the shifters just twist out or something , or do you have to cut them out and weld, then weld them back in???
help please :-\
Don't know about the suzuki shifters but I did it in a toyota, it was simple
1. remove the boot
2. was like 4 10mm bolts & snap ring holding the shifter in
3. pulled right out
4. re-installed in reverse order
The suzuki's should be similar
Hope that helps some
Steve
Suzuki is easy, remove boots, then there shound be a spring loaded collar that is down in the transmission, press down, turn (ccw I think) and remove, then the shifter will pick up out of the transmission.
I extended mine in the straight part.
does anybody have any pictures with what they did to extend their shifters...
any bodylift installs with this part covered on the net.??
thanks for the help all.
does anybody have any pictures with what they did to extend their shifters...  ÂÂ
word,
http://www.granitepath.com/friends/kd7hcg/pictures/bodylift/page2.html
some good pics ;)
stu
thanks again all. zukiworld is really a mecca of sorts. ;D
