ZUKIWORLD Discussion Forum => Suzuki 4x4 Forum => Topic started by: Effzuki on July 14, 2005, 05:01:55 AM
Title: 92 Tracker 1.6, What should I look for.
Post by: Effzuki on July 14, 2005, 05:01:55 AM
Hello,
I'm looking at a 92 tracker with 115000 miles on it for $325.  It was involved in an accident and looking to put the engine in a 87 Tin Top.  I'm looking for any advice on what I should check/how I should check items on the engine.  eg. compression of the engine, looks like the value cover area might have some oil around it.  Is that common?  Thanks in advance.
Title: Re: 92 Tracker 1.6, What should I look for.
Post by: zaggy on July 14, 2005, 06:50:42 AM
Look it over and run it....do a compression tst if you can
Check oil etc, just as if you were buying a driver
Zag
Post by: Effzuki on July 14, 2005, 07:56:35 AM
I bought a compression tester to check the 1.3, but have not used it.  I thought about rebuilding the 1.3, then thought better of it.  Thinking that if I pull the engine, might as well put a 1.6 in.  What should the compression be?  And what is an acceptable reading between the cylindiers?
Post by: zaggy on July 14, 2005, 08:21:04 AM
I like to see 130-150 on the guage after about 6 turns of the engine....
You know you need an adapter to mate to the 1.3 trans? And some other tinkerin
Zag
Post by: SnoFalls on July 14, 2005, 10:24:22 AM
my tired 8V is 130-135 on all 4 ... what you want on the comp test is all around the same ... one low will probably indicate bad valve (usually exhaust). Under 130 is pretty worn out IMO. Hope for 170's :)
Leaky valve cover isn't uncommon. The valves need regular (aka every 60K mile) adjustment, so my guess is that someone reused an old gasket, and now it leaks.
Post by: Effzuki on July 14, 2005, 11:37:43 AM
You know you need an adapter to mate to the 1.3 trans? And some other tinkerin I was going to talk to Brent at TT and see what all is needed.
Thanks for the info.
