ZUKIWORLD Discussion Forum => Suzuki 4x4 Forum => Topic started by: ussexplorer on March 25, 2005, 07:52:05 PM
Title: Fog Lights
Post by: ussexplorer on March 25, 2005, 07:52:05 PM
Were do you plug in your fog lights? Directly to the battery or to the fuse block? I don't really see any extra spaces on my fuse block in my sidekick.  How do you have yours connected up.
later,
Josh
Title: Re: Fog Lights
Post by: JDMCRX on March 26, 2005, 12:46:50 AM
Best to use a relay use a power wire fused 18" from the battery or less. Then a remote wire from a switched from ur fuse box to ur own switch
That way when u  turn the ign off they will turn off.
GO to www.hella.com
thay should have some wiring diagrams
Post by: shilly on March 29, 2005, 03:27:35 AM
If you buy a relay from a jobber like Advance the wiring diagram comes with the relay, too.
Post by: ussexplorer on March 29, 2005, 03:57:46 PM
Yea, the kits I was looking at came with a relay. I didn't think about that. having them turn off with the truck. Would suck to have a dead battery.
later,
Josh
Post by: budzooka on March 29, 2005, 04:13:23 PM
where were you going to mount them? i just put in a set of hallogens right in between the rad and the front fender support , behind the grill. you cant see them and they are protected but when they come on they light up awesome!! there is a lot of room in that spot for different styles. just a thought.
Post by: ussexplorer on March 29, 2005, 07:22:49 PM
well on the 92 kick 4 door. i got two choices. One is in the oval inlet on the front of the truck. I have seen them in there before and they look good. Providing I get the small oval lights. The next place and not really a better idea. There is two predrilled holes in the frame in the front. They don't look like tow hitch holes or anything usefull. So I assume it might have been were stock fog lights might have been mounted. Though I would question how they would do off-road. I think they would be high enough up not to matter.  If I get the nice metal ones that say bend back and not break like some.
Later,
Josh
Post by: shilly on March 30, 2005, 03:29:11 AM
This may sound kind of redneck (hell, it IS kind of redneck...lol) but I simply used two metal hose clamps around the bracket of each light to hold them to the frame tube under the front bumper.  They've been there for over a year with no problems.  Say what you will, but it works!! :)
Post by: ussexplorer on March 30, 2005, 07:14:42 PM
I probably would have used scotch locks. you know those plastic lock ties or whatever I could have found laying around.
later,
Josh
