ZUKIWORLD Discussion Forum => Suzuki 4x4 Forum => Topic started by: madvitara on March 25, 2005, 06:32:28 AM
Title: lock right diffs
Post by: madvitara on March 25, 2005, 06:32:28 AM
Does anyone now if a samurai lock right diff will fit in a side kick housing?
Title: Re: lock right diffs
Post by: SuzukHunter on March 25, 2005, 10:12:38 AM
should they are a little smaller.i know that a kick will fitin a sami hausing.
Post by: coyhunter on March 25, 2005, 11:46:29 AM
Think so give hawk suzuki a call (888-samurai) I was just talking to them about an all steel dif front with a locker for my tracker and he was talking about using the samurai carrier in there because they are not making a lock rite for the front   yet though it is suppose to be out soon. (I think he said something about changing side gears).
Post by: mbmarkyb on March 25, 2005, 06:38:10 PM
when i got my locrite  it said vitara/sammy on it....i would expect the spider gears are the same
Post by: purevil71 on March 26, 2005, 01:12:30 PM
The one in my Samurai came out of a Tracker
Post by: xamtex on March 26, 2005, 11:58:15 PM
the sammi lockright will fit the kick FRONT, the kick rear is different.......bigger alltogether................................
the kick front is the same size as the sammi,just a different ratio.also the kick diff has an ally casing which is weaker than the steel sammi casing.so for strength build the kick ring and pin into a sammi steel third using the sammi lockright..... ;D
Post by: Chief on March 27, 2005, 12:02:33 AM
OK, so a sammi lockright will fit in a tracker front end, with NO modifications?
Time to start blowing the front end up!  8)
Post by: Chief on March 27, 2005, 11:26:32 PM
