ZUKIWORLD Discussion Forum => Suzuki 4x4 Forum => Topic started by: naor on September 04, 2005, 10:04:46 AM
Title: adumbration of front spring spacer - sidekick
Post by: naor on September 04, 2005, 10:04:46 AM
Hello everybody.
I have 4 doors 1997 sidekick. Yasturday i put spacers to get the body-lift of 30 mm.
I do not have the adumbration of the front spring spacers, and right now, there are only shock absorbers spacers at the front, of 30 mm (above the shock absorber, which is original).
At the back I put the spacers above the spring, and changed the shock absorber to KONI sport (longer the original).
The back spring spacers: 110 mm external diameter, 100 mm internal diameter and 70 mm middle hole. 45 mm external height, and 30 mm internal height which gives 30 mm lift up.
If anyone could please send me by e-mail a.s.a.p the adumbration of the front spring spacers, I would be greatfull.
Right now, I drive with only shock absorbers spacers at the front, and it could cause damage.
Thank you all in advance.
My e-mail: naor|removethispart|@perry-law.com
Title: Re: adumbration of front spring spacer - sidekick
Post by: wildgoody on September 04, 2005, 11:43:05 AM
30mm rear lift is not much, about 1-1/4 inch.
The ratio of  lift in the front is greater, a 25mm
spacer would give you about 1-1/2 inch lift, or
about 37-40mm which would put your front close
to the back, as the rear was a little higher than the
front when at stock ride height
