ZUKIWORLD Discussion Forum => Suzuki 4x4 Forum => Topic started by: zuki4fun on September 19, 2005, 08:43:45 AM
putting new bearings in the rear of the sammy. dose any body know the torque specs for the pinnon bearing nut and the carrier bearing retainers????????
Did you get a new crush sleeve too ?
If the new bearings have a slightly different
dimention, the shims need to be adjusted,
and the crush sleeve takes massive torque,
like 300-400 ft lbs to get started crushing, once
it starts to torque drops off sharply, but I would
use and impact to get it started.
Retainer, you mean the little 12mm bolts or the
17mm bolts ?? the little ones don't need much
15ft lbs should do, the 17mm need to be tight,
I just zap them on with a 1/2" impact and get
done with it
