ZUKIWORLD Model Specific Suzuki Forum => Suzuki Grand Vitara, Vitara, Chevy Tracker (Gen. 2 Platform) 1999-2005 => Topic started by: sergi on September 20, 2005, 05:02:11 AM
I rotated my wheels the other day (they will get changed some day ::)), and noticed a dent and bump on my chassis. It's on the front right, right where the flat part of rail goes upwards toward the spring perch.
You can see a bump on this side of the rail:
(http://fotos.miarroba.com/fotos/6/5/652986a0.jpg)
This circle is totally deformed,and you can see the bumps on either side:
(http://fotos.miarroba.com/fotos/7/f/7f5d79a2.jpg)
This is the other side, how it should be:
(http://fotos.miarroba.com/fotos/8/4/84641a69.jpg)
I wonder how I hit that part so hard yet the catalizer which is right next to it is intact.
The question is, should this be adressed? I am not worried about it right now, just thinking that on the long term it might get worse. Hasn't anyone experienced this? Any solutions/reinforcements needed?
Thanks for any help! :)
I would suggest welding a plate along the face of the verticle side of the frame. It wouldn't have to be too big. This would keep the frame from buckling and you actually having a problem. Something similar to the way Hagen reinforced his frame modifications on project "RockStar". That should work.
Good Luck, Eric
Thanks!
Do you mean something like this?
(http://www.zukiworld.com/month_010105/images/hagen_rockstar/10frameweld.jpg)
Foto by Mike Hagen at http://www.zukiworld.com/month_010105/feature_operationrockstar_partone.htm
So a few plates on top (without cutting my existing frame ;)) and that should be it... I'd better start practicing my welds ;).
Thanks!
Thanks!
([url]http://www.zukiworld.com/month_010105/images/hagen_rockstar/10frameweld.jpg[/url])
Foto by Mike Hagen at [url]http://www.zukiworld.com/month_010105/feature_operationrockstar_partone.htm[/url]
Thanks!
Yes, like that only you don't need to cut the frame and probably wouldn't need a plate anywhere near that big.
.... but that is the idea.
Sorry for the late post but it almost looks like it slipped off a car lift, I've seen this before, just a thought. Dave ;D
