ZUKIWORLD Discussion Forum => Suzuki 4x4 Forum => Topic started by: Zukipilot on September 22, 2005, 10:18:43 AM
Title: QUICK TROUBLE SHOOT PLEASE 1.6 MOTOR
Post by: Zukipilot on September 22, 2005, 10:18:43 AM
My friend is working on a 92 Tracker and cant get it to run. He is getting fire and fuel to the motor but no injector pulse. Any ideas of what could be wrong?
Thanks Zig
Title: Re: QUICK TROUBLE SHOOT PLEASE 1.6 MOTOR
Post by: zaggy on September 22, 2005, 10:33:02 AM
I hate to say this but I think it's probly one of 2 places
- Poor connection or somehting hooked up wrong
- ECU
Typically no injector pulse from my experience is ECU
Best guess...
Zag
Post by: Zukipilot on September 22, 2005, 10:43:29 AM
Cooll thatnks Zag, that was Mikes conclusion too. I will let Jimmy know.
Post by: ppltrak on September 22, 2005, 12:02:52 PM
Zig, also when the key is in the on pos there should be 12V on one side ov the inj. conn. If there isn't you have a powefeed prob. and check the feed ckt.
     Kevin
Post by: bandit86 on September 22, 2005, 02:23:19 PM
Thanks Zig
you cant have one without the other.
Post by: locjaw on September 22, 2005, 05:32:51 PM
had the same prob a couple of months ago on my nissan truck, took my mechanic 2 weeks to trouble shoot it cause everytime he would put the scanner on it it would fire up again(really messed with him)ended up being a corroded plug at the batt terminal that was the main power for the computer. had fuel press at the rail, had spark, would run when i would dump fuel into the air body.
look at those plugs, might be the problem
jason
Post by: BV1 on September 22, 2005, 09:22:08 PM
I had the same problem with my X when I did the swap,
I was getting fuel, fire, ignition, compression, detonation but no combustion?.....
Wait, that was a bad dream... nvm
-Steve
