ZUKIWORLD Discussion Forum => Suzuki 4x4 Forum => Topic started by: bashzuk on September 25, 2005, 10:09:01 AM
Title: Where would I get 2 LO for transfer case?
Post by: bashzuk on September 25, 2005, 10:09:01 AM
Does anyone know  of somewhere to get a new shift sheet that has a 2 lo option other than rocky road.
Title: Re: Where to get 2 LO for transfer case
Post by: locjaw on September 25, 2005, 10:16:13 AM
you dont need a kit for the sammi all you do is leave the center detent ball out , but......
dont do it, it aint worth it  >:( mine started to slip into0 the 2 wd shift pattern all by itself(especally when you dont want it to).
i put the ball back in, problem solved!
jason
Title: Re: Where would I get 2 LO for transfer case?
Post by: 37kicker on September 26, 2005, 11:39:25 AM
I would go with a twin stick type shifter . what for a kick or sammy?
Post by: brlj on September 26, 2005, 05:43:15 PM
Hey Stan, PM me if you know where I can get a twin stick for a Tracker transfer.. ;)
Bill
Post by: bashzuk on September 26, 2005, 06:26:23 PM
This is for a sammy. twin stick is patented and I have no fabrication skills.
Post by: bhaugen on September 29, 2005, 07:32:01 PM
Here is a good write up on how to do it.
http://www.izook.com/tech/samurai/drivetrain/2wdlow/2wdlow.htm
I am running the 2wd low and it works fine.  It is great, not perfect, but it works.  Not as good as a Twin stick, but hey it works, and I am not going to go through the pain to make a twin stick.  I have never had mine jump out of gear ???
Post by: ed oorklep on September 30, 2005, 02:41:30 AM
Don't you have manual hubs, that's real easy 2wd Low  ;)
Post by: LiftedSuzuki on September 30, 2005, 02:41:21 PM
2nd that  :P -David-
Post by: 37kicker on October 01, 2005, 01:40:28 AM
patent,  for a twin stick????      i am building a dual shifting kit for a sammy    sorry  for the confusion.   I all so  have dual shifters for kicks ! ;D ;D
