ZUKIWORLD Discussion Forum => Suzuki 4x4 Forum => Topic started by: Festiva on October 05, 2005, 11:46:58 AM
Hi guys, my 94 tracker has the canister on the left side of the motor, it has just a single nipple on the top of it (unlike some that have 2 nipples.) but no vaccum line hooked up, where does this go?
Thanks!
Jason
Strange, should have 2, if you are sure
there is no purge nipple, the one should
go to the Gas Tank
Thanks!
Jason
Yep, there should be two. One has a hose that goes back to the gas tank, the other goes to a vacuum valve mounted on a bracket above and inboard of the thermostat housing on the front of the intake manifold (or thereabouts). At least that is the case on my 93 and 96 16-valves.
