ZUKIWORLD Discussion Forum => Suzuki 4x4 Forum => Topic started by: SnoFalls on October 10, 2005, 07:00:28 PM
Title: breathers
Post by: SnoFalls on October 10, 2005, 07:00:28 PM
hmmm ...
Looks like the breathers for the tranny and tcase came undone when I did my 3" BL in the new rig ... (always forget to loosen something ya know).
I felt around and I just can't see feel where those hoses go. Anyone got a pointer on where to feel so I can get em hooked back up?
Funny thing is, I noticed some watery oil splotches as I was "adjusting" the shifter levers going fwd/rev in the shop ... note I said "watery" ... doh, wonder if that winey trans is in need of oil and not water! I'd checked and the tranny was full (but I may now know full of ...)
Title: Re: breathers
Post by: crikeymike on October 11, 2005, 12:10:28 PM
Mine didn't come disco'd from the tranny itself, but from the points by the distributor where they actually vent.
You could take a minute to drop the tranny and t-case, and then let us know where it was....
I don't think that helped.
I'm pretty sure that the metal tubes they slide onto lay kinda flat, instead of sticking up.  Kinda like a 90 degree bend out of the top of the boxes.
 ??? ???You could drop the fluids and let it sit for a while empty, then take some air and blow up into it and see where the air comes out... (reverse flush, but with air...)
Post by: Dihnekis on October 11, 2005, 06:49:27 PM
Sorry to threadjack, but I've got a quick question about building a snorkel. They say you have to connect the breather tubes to the snorkel from the tranny, t-case, and diffs, where do they come out at?
Post by: SnoFalls on October 11, 2005, 07:13:47 PM
yea I found em tonight ... musta ben tired yesterday. Once I found one, the other was easy to locate using the other hose as a guide ...
Post by: SnoFalls on October 11, 2005, 07:18:12 PM
the front diff hose comes up near the charcoal cannister, the tranny/tcase hoses connect together and share a hose coming up behind the engine near the distributor, and the rear diff hose goes to the rear and up into the body.
you could tie the 2 front hoses together and route them to the snorkle, and the rear should be fine (if you're that drowned, the comp probably is too).
Post by: Dihnekis on October 11, 2005, 07:51:10 PM
Is that the same on a samurai?
Post by: Rhinoman on October 12, 2005, 09:21:08 AM
No the Samurai has little caps on the diffs. You have to pull them off and attach a hose instead.
