ZUKIWORLD Discussion Forum => Suzuki 4x4 Forum => Topic started by: steveofrost on October 19, 2005, 08:33:58 PM
What does this mean for a warning light on my dash:  (!)
Any help would be great... I think it has something to do with breaks, but the E-break isn't being used and I have topped up my fluids... what else can I do... Jeeez, something must be wrong 'cause my ride just doesn't 'feel' right....
steveo
does it stay o n all the time? cuz if you use the e brake lots some times that little switchy thing needs a little tweek.. or it could be some thing else... try it and see
oh yah it's the e brake light....lol
I used to see that sign only when I would take a turn fast or brake hard, and then I got my front brakes changed and I'v never seen the sign ever again.
It's low brake fluid or E-brake is on,
or switch is stuck/out of adjustment
Yeh check your brake fluid level, you should be able to do it pretty simply, if the level is low top it up.
If that doesnt work, i would think about getting the brakes checked by a garage, they are quite an important part!!! ;D
It's the PAY ATTENTION light. It should be on at all times. ;D
The ! is also called "the bang symbol" to Unix and Coding geeks...
so.. maybe it means it's a "Bang Warning Light"? Like if you don't pay attention to it, something might go... "BANG".
;D
mine was on perminitly, and i was confused, turns out both of my brake lights were burnt out, put new bulbs in and it shut off.
Well thats what happens on the uk models!
Thanks all for the quick responses. I topped up brake fluid. I'm having some exhaust work done at a muffler shop that does brakes as well, so I'll get them to check the front and rear brakes. I was hit a while back and my brakes were smoking bad that night, so maybe they need to be looked at asap. Winter is coming and I think it would be a great idea! One more thing though: How do I 'tweak' my switch for the light on the dash, if everything checks out ok that is... I had my ECM replaced as well a while back, so I guess this warning light could be from a many number of things! Joy! Thanks again all,
steveo
