ZUKIWORLD Discussion Forum => Suzuki 4x4 Forum => Topic started by: Maiden Hell on November 06, 2005, 12:33:25 PM
Is there any way to hook up a second 12 Volt accessory socket to the same harness is the original (or cigarette lighter in some cases) one is already plugged into? I really need a second one badly as my collection of car adapter electronics is quickly rising.
I added a triple socket unit to the bottom of my radio box and ran it directly to the battery in case I wanted to run a spot light or whatever.
Do Trackicks only come with one socket ?
Reason I ask is Escudo's have two, one for the ciggy lighter and one 20 amp outlet for extras.
Yup, just one.
And I have ZERO, because I put my Air Tank Pressure Gauge in the hole where my cigarette lighter was. Now I need one for my laptop, for when I'm tuning my MegaSquirt.
Yup, just one.
LOL that's why I need a second one, for my laptop as well. The other one is to plug in an FM transmitter so we can get sound through the audio system. We're going to Quebec this up coming weekend and need some entertainment for the road. :)
But I found an adapter that creates two outlets by plugging into the original socket!
Hey if you want a factory duel outlet I have two parts trucks sitting out back with them in, PM me with your address and I'll check to see if it's not going to cost me an arm and leg to ship remembering I'm down in New Zealand and send you one. You could be the first northern hemisphere Kick with factory duel outlets ;D ÂÂ
EDIT: Bob do you want the other one ?
go to canadian tire and get there double or triple out that plugs into the same and just look at each piece of equipmend to see it will be more than your fuse
