ZUKIWORLD Discussion Forum => Suzuki 4x4 Forum => Topic started by: THORSZUKI on November 17, 2005, 03:45:11 PM
I read somwhere Crown Vic shocks fit on a Sidekick.
Is this true and what is the benefit..are they cheaper....Longer.....extened more....if it is a good thing do you order the same year as your Kick?....anyone know about this it would be good info.
it is my understanding these are best when used on the rear of the vehicle when installing spring spaces and doing the strut mount flip trick. I think the goal here is to give a little bit of extra down travel in the rear suspension to prevent it from banging into the end of the shocks when hitting the top limit of the rear suspension
You can only do the Crown Vic shocks
if you want your Track/Kick to look like this
(http://wildcatent.freeyellow.com/suzuki-rock.jpg)
what years do you guys recomend to use
Check these links:
http://www.zukiworld.com/forum/index.php?topic=9146.0
http://www.zukiworld.com/forum/index.php?topic=809.0
http://www.zukiworld.com/forum/index.php?topic=8693.0
And the list goes on and on... just use the search button above and type in "crown vic" You'll get plenty of answers! LOL! ;)
anyone have some specifications, I have 1.5 inch coil spacers waiting to be install this looks like a good add to it.
Just click some of the links I posted! LOL!
All the info you could possibly want is contained in them!
I used 91 crown vic shocks and they measure 1-1/2" longer than stock, mount the same way as stock and are $5 cheaper each than stock (when purchasing Monroe Gasmatics at Advance) and they are perfect with 1-1/2" spacers. ::) ;D
Thanks a ton the information is perfect :)
Im using a pair of Monroe Sensatracks from a 91 Crown Vic. Unreal soft ride from the back. best money ive spent.
rear shocks off a 93 e150 work well too. they are 2" longer than stock.
derek
Depending on the size of your lift, Rocky Road has doetch tech shocks that will fit and provided extra travel. Check out the article on the rocksteady kit in the gear guide section.
