ZUKIWORLD Discussion Forum => Suzuki 4x4 Forum => Topic started by: SidekickMN on December 04, 2005, 10:50:30 AM
Title: Sidekick Engines
Post by: SidekickMN on December 04, 2005, 10:50:30 AM
I was just wondering if the track/kick engine are interference fit.  I need this info to try and figure out why my engine blew up.
Title: Re: Sidekick Engines
Post by: wildgoody on December 04, 2005, 10:55:13 AM
No, I tested both 16 and 8 valve engines.
Some others have said they do have interference
engines, but these might be Spanish models with
a different power plant
Post by: ack on December 04, 2005, 10:59:55 AM
Ditto on that.  North American OEMs are non-interference.
Did the connecting rod on Piston #3 try an escape attempt?
The curious ones want to know what happened...
Post by: SidekickMN on December 04, 2005, 11:17:54 AM
well this just happend last night there no obvios damage on the outside but ill let u know what happend when i take her apart.
Post by: Rhinoman on December 04, 2005, 01:14:56 PM
Spanish 1.6 engines are the same as the Jap engines.
Post by: lil_Truck on December 04, 2005, 03:31:45 PM
I'm drawing a blank.  What are you calling interference and non-interference engines?
Post by: derekj on December 04, 2005, 04:12:36 PM
on an interference engine when the timing belt breaks the valves will hit the top of the pistons and non interference wont hit.
derek
Post by: lil_Truck on December 05, 2005, 05:22:08 AM
That was the conclusion I had came to.
I'm supprise there not, but it will be good to know.
Post by: aceluck on December 05, 2005, 07:26:21 AM
Does anybody know if the 2.0L of the post-1999 TrackVits is an interference engine?
Thanks.
Post by: wildgoody on December 05, 2005, 08:23:35 AM
Because of the reliability of a chain, as
opposed to a rubber belt, many are of
the interference type, but I don't know
which ones are or are not.
Post by: zaggy on December 05, 2005, 08:55:54 AM
The J Series (1.8-2.0) are interfereance engines
Blow the chain...toast the valves...got one in the shop right now.
Zag
Post by: Bobzooki on December 05, 2005, 08:59:13 AM
Wait a minute.
The 1.6L 8-valve is NOT an interference engine, but the 1.6L 16-Valve engine IS an interference engine.  It says so right in the FSM.
Post by: pecs on December 07, 2005, 09:15:27 AM
My manual says the 16V is an interference motor as well, but I never checked for valve clearance myself.
Post by: wildgoody on December 07, 2005, 09:31:47 AM
Wait a minute.
So you would think, many 16V engines are, but
I personally put the engine at TDC and turned the
cam by hand, no hitting of valves, maybe while running
and breaking you might have a different story, but I
checked it just for the info to know first hand
