ZUKIWORLD Discussion Forum => Suzuki 4x4 Forum => Topic started by: SidekickMN on December 11, 2005, 03:04:34 PM
Title: Connecting rod
Post by: SidekickMN on December 11, 2005, 03:04:34 PM
some of u seemed intrested in what happend to my motor.  So to let u know the connecting rod in piston #3 decided to go through the block.  And i was wondering if this has happend to eny one else
Title: Re: Connecting rod
Post by: ack on December 11, 2005, 05:01:47 PM
Are you ready for this?
I have seen it THREE times!
All on Samurais
The most common cause, I believe, is lack of lubrication either because someone forgot to top off the oil (eg, teenage daughter disease)  or - and this is my theory -  the mechanical fuel pump's diaphragm was punctured and gasoline thinned out the oil until the engine failed.  And the 1.3 engine has a mechanical fuel pump.
Do you have a 1.3?  or a 1.3 head on a 1.6 block?
If you don't have either of the above, then I'm stumped...
Post by: SidekickMN on December 11, 2005, 07:59:14 PM
i have a 1.6 liter 8v and i did an oil change 200 miles before this and the oil level was right.
