ZUKIWORLD Discussion Forum => Suzuki 4x4 Forum => Topic started by: BigPig on December 19, 2005, 10:56:37 PM
Title: Sidekick tire/wheel advice?
Post by: BigPig on December 19, 2005, 10:56:37 PM
I have a stock '89 Kick soft top.  I am looking at a 2" body lift and 2" coil spacers.  What size tires can I fit with what wheel offset?  Thanks for the help.
Title: Re: Sidekick tire/wheel advice?
Post by: wildgoody on December 19, 2005, 11:19:28 PM
235s easy and 30s OK, use the stock wheels,
or a narrow 6-7" wheel with about 3" backspace
Post by: wedge on December 20, 2005, 01:30:42 PM
Ialso have an 89, and I run 235/75/15 on stock rims/ stock height.  I'm planning to go to 30s on 7"wide rims after I put on my 2"coil spacers.  my 235s don't rub at all either.
Post by: 94track on December 20, 2005, 02:15:40 PM
My last rig had 1 1/2 " coil spacers with a 3" bl, and fit 31 x 10.5 tires with a 2" backspaced wheel(8" wide).  I am a fan of the 3" body lift, IMO the extra inch makes a world of difference, it is more work, but still a simple installation.
Post by: derekj on December 20, 2005, 08:59:35 PM
i run 31's in the summer with a 2 & 2 combo lift. i'm not too sure what the back spacing on my wheels are but it does not rub after a few small mods to the front wheel wells with MR.H
derek
Post by: 89kick on December 21, 2005, 09:54:23 PM
heh i say just go the whole 9 yards and doa  6" combo lift and fit on some 33x12.50s on 15x10 rims  a slight trim to the outermost edge of the front fenders on the back side fixed all my rub.  in fact you can hardly tell i trimmed up the fenders. no with a 4 inch combo lift i would say you should be able to fit 30s comfortably.
Post by: Mikerpm4x4 on December 22, 2005, 07:38:03 PM
I agree with Wild on the 235 or 30s. I would also try to keep the wheel and tire combo as light as possible. Light tires wont steal as much power as heavy ones.
Mike
Post by: 89kick on December 24, 2005, 12:39:17 AM
also the hiegth of the tire changes the gearing a lot on the output so it can be kinda tricky.
